Old 01-01-2018, 01:34 PM   #1
operating slide outs and hydraulic jacks in below freezing temps
how does the weather affect the operation with slide outs and jacks in weather in the teens?
Happy Campers
CAD-on the road again is offline   Reply With Quote
Old 01-01-2018, 01:38 PM   #2
Just now at 22 degrees 1 hydraulic jack hung up I went over and kicked it and it came back up cleaned the snow off the top of the slides and they all came in just fine
If not camping, I am Sailing
JohnVtx is offline   Reply With Quote
Old 01-01-2018, 10:32 PM   #3
dieselguy's Avatar
Really cold weather makes the hydraulic oil thicker and harder to pump. The motor draws more amps to run and the whole system runs slower. Sometimes it will pop the resettable breaker for the hydraulic pump in your front storage compartment.
dieselguy is offline   Reply With Quote
Old 01-02-2018, 07:06 PM   #4
thanks for your info
Happy Campers
Old 01-02-2018, 10:08 PM   #5
97flhtcui's Avatar
It was 18 deg this morning and my level up and slides worked as good as the do in 80 deg weather.
2019 Ford F-250 6.2l gas 430 E Lock
2015 Cedar Creek 34RL
MORryde IS 7000 LB
Kodiak Disc Brakes
97flhtcui is offline   Reply With Quote
Old 01-02-2018, 10:15 PM   #6
NMWildcat's Avatar
You are literally the first person I've heard claim this. Did you change the weight of the fluid used or put in an additive? Maybe heated storage
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 01-03-2018, 12:18 AM   #7
Have done front jacks in low teens. Lowest for slides has been in the 20's in Stone Mountain, GA. Groaned a bit but still worked ok.
Rich5117 is offline   Reply With Quote
Old 01-03-2018, 03:19 PM   #8
dieselguy's Avatar
Quote "It was 18 deg this morning and my level up and slides worked as good as the do in 80 deg weather."
Unless you have switched over to all electric slides and jacks ... I just can't get this down even with a full cup of coffee. Like Scott asked ... do you have some super fluid in the reservoir?
Old 01-03-2018, 09:49 PM   #9
Thanks guys...I pop the hydro breaker all the time in cold weather and started to think I was alone
birdman77 is offline   Reply With Quote
Old 01-03-2018, 10:04 PM   #10
John Deere could use your "Secret" on how this works,on both the AG and Ind Divisions! Youroo!!
Old 01-03-2018, 11:37 PM   #11
97flhtcui's Avatar
We full time and have never had problems with temp and the hydraulics. When y'all get and answer you don't like you make fun of the person instead of trusting what he says. It was 14 deg in Junction Texas on The morning of Jan 2nd. When I pulled in my slides and lifted my level up it was 18 deg. It worked no different then any other time. They don't put 80 wt I'm in them so why would you notice.
MORryde IS 7000 LB
Kodiak Disc Brakes
Old 01-04-2018, 01:58 AM   #12
Boatdude62's Avatar
15 degrees today and used the level up system to change tires on a stock 2013 CC. Everything operated the same as if it was 80 degrees. Will turn heat on to warm up insides before I attempt to open slides. May not be needed, but we have to pack anyway, want to do it in a warm camper...lol.
Boatdude62 is offline   Reply With Quote
Old 01-04-2018, 06:26 AM   #13
DDC
DDC's Avatar
Itís a little slower in the cold, but the oil is denser when cold, I also must say Iím a bit slower in the cold and maybe a bit denser too
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 01-04-2018, 06:32 AM   #14
Amen brother !!
TheWolfPaq82 is offline   Reply With Quote
Old 01-04-2018, 07:45 AM   #15
A well maintained 12v dc hydraulic power unit will not have a problem working correctly in below freezing temps. The hydraulics on your camper are basically the same as what is on a pickup truck snow plow witch operate with the same atf fluid as what is in your camper system. With that being said there are low temp hydraulic fluids that will replace atf and provide better performance in cold weather but they come at a higher cost
lbrunning is offline   Reply With Quote
Old 01-04-2018, 10:45 AM   #16
NMWildcat's Avatar
I think all of us maintain our rigs, or we wouldn't be using them. And none of us has said they don't work correctly in the cold, they just don't function the same, as in they are slow and more apt to trigger pressure solenoids and electric breakers. Under 30 degrees my jacks/slides might take four attempts to bring in, where at 90 they come up/in the first time. I've been looking for a hydraulic fluid that works at 115 AND 20. So far aviation type looks promising.
Old 01-04-2018, 11:18 AM   #17
Kanadian Kamper
kenandterry's Avatar
Are we all using electrics or hydraulics or a combination?
Forest River seems to use a variety of components for all their products, so no one should assume other rigs operate and are designed the same as theirs.
Letís make sure what mechanism each of us is quoting.
Ken and Terry
2018 Sunseeker 2430S-CD
and if we ever need it, can be pushed by our 2017 GMC Terrain toad (4 wheels down)
Former Georgetown 330TS owner for 10 years with more mods than I can count.
kenandterry is online now   Reply With Quote
Old 01-04-2018, 11:32 AM   #18
NMWildcat's Avatar
Thread title states hydraulic..........
Old 01-04-2018, 12:25 PM   #19
CC75's Avatar
Ambient moisture may have something to do with varying experiences at the same temperature.
CC75 is offline   Reply With Quote
Old 01-04-2018, 12:52 PM   #20
I put the anti-stiction fluid in from cat because of the jacks making a clunk with differing temps after seeing for a while. This fluid is supposed to help with cold weather operation.
hydraulic, jacks, slide, slide out
