Old 10-18-2020, 12:24 PM   #1
Outside tv
I recently purchased a 2017 38EL champagne edition. I am on the rv antenna and can't get any reception on the outside tv. I can do a channel search but it doesn't pick up any channels like the other 2 tvs.
Steven Spears is offline   Reply With Quote
Old 10-18-2020, 01:02 PM   #2
jeff64's Avatar
Is the tv input on air/antenna before you scan for channels? Is there more than 1 connection on the antenna plate? Did you push the power button to the antenna amplifier?
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
Old 10-18-2020, 01:04 PM   #3
Last time it was used, were you using cable? Maybe the last owner left it set for cable?
Twice retired
2015 Forest River Sunseeker 3170DS
Mask it or Casket?
What is in your future?
Ladaca is offline   Reply With Quote
Old 10-19-2020, 11:36 PM   #4
No, its set on air. It will go thru a channel search but won't pick any up and the other 2 tvs pick up 20 or more.
Old 10-21-2020, 02:12 PM   #5
Was this the first time using the outside coaxial connection for this TV?
karpcbk15 is offline   Reply With Quote
Old 10-22-2020, 07:31 AM   #6
No, the guy i bought it from said he watched it before but that you could only watch whatever the bedroom tv was tuned to?
Old 10-22-2020, 07:52 AM   #7
There should be a 3 way splitter somewhere, probably near the amplifier. They usually link all TVs for cable or antenna watching. Maybe a loose connection or bad 3 way splitter.
DYNAMAX 2016 FORCE HD
houstonstroker is offline   Reply With Quote
Old 10-22-2020, 10:44 AM   #8
kc8lvy's Avatar
On my RV even though it is not a Forest River product alot of them share slot of similarities, on my connections inside my RV on my livingroom tv I have 3 hook ups.
#1 is for air/cable, #2 is for outside tv and #3 is for Satillite. If I want to watch my outside tv on air I install a splitter their and short cables to connect the #1 to #2 and to my living room TV. Yours may be similar. If not for a test if you are on air, hook up a cable from your outside cable to your outside tv and do a channel scan. Good luck.
2004 Dodge Ram 2500HD Cummins
2017 Keystone Montana 3820 FK
2009 Harley Davidson Ultra Glide
kc8lvy is offline   Reply With Quote
