Old 06-13-2018, 11:58 AM   #1
Pin box
Does anyone have the trail air pin box on there fiver? How do you like it and would you recommend?
Joepoohbah is offline   Reply With Quote
Old 06-13-2018, 12:06 PM   #2
Here is a link to past discussions on the TrailAir
TrailAir
Days Camped: '18=51 '19=58 '20=110 '21=94
Old 06-13-2018, 07:37 PM   #3
The front cap faded and while at the factory getting it replaced I was asking about TrailAir and the factory installed one at a good price. Driving on the road I can see the camper moving up and down, so it does work. Itís a air bladder and it tends to lose air over a couple of weeks. MORryde is a pin box, if I had it to do over I would get the MORryde, no bladder. Your trailer has to be hooked up to put air in the bladder. Normally itís three months before I add air to the tires. I have a TPMS TST 507 and the tires hardly ever lose any air. Itís kind of a hassle for me to air up the bladder right before I start riding for the day.
spock123 is offline   Reply With Quote
Old 06-14-2018, 09:08 AM   #4
Jim34RL's Avatar
I would not tow a trailer without one. This is my second trailer with the TrailAir pin box installed on my trailers. I installed a TrailAir pin box on my Cougar in 2010 and with the Cedar Creek I ordered the box from the factory all ready installed..
For airing up the bladder on the pin box I carry a portable air tank in the bed of the truck that I purchased from Harbor Freight. This is a 6 gallon tank and is pressure rated for 135 PSI. I have been using this tank since my first 5er when I installed the air box on it.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 135K+miles
Old 06-14-2018, 09:27 AM   #5
Towed my fiver 12 years with one. It does make a difference!
donniedu is offline   Reply With Quote
Old 06-14-2018, 07:00 PM   #6
I with Spock. I have one and you can see the trailer move up and down. But it can only move a couple inches, how much good can that do? I am tired of adding air to it when I use it. I've done all the usual things to the valve and it still looses air somewhere. <ime is going away and will be replaced with a Morryde. The Trailaire does nothing for the chucking which is my biggest problem. Have never hear anyone complain about a Morryde.
2015 Chev Silverado 3500 dually D/A
2016 Cedar Creek 36CK
B&W Patriot 18K, Trail-Aire pinbox,
Level up, dual panes & all that stuff...
GOTTOYS is offline   Reply With Quote
Old 06-14-2018, 09:09 PM   #7
Not necessarily Spock. I aired mine up connected then disconnected and check the air pressure. Turns out on my Trail Air at 80 PSI disconnected is prefect when I connect. So I just check and air up to 80 before hooking up.
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
mwdilday is offline   Reply With Quote
Old 06-14-2018, 09:15 PM   #8
Always Learning
After a few years of having one and now in a new trailer without one, I sure wish it did.
I'll either be adding one or the MorRyde. I'll probably go for the MorRyde since I'm generally not a huge fan of Lippert products.
OR- I'll go nuts and go with a Trailer Saver air ride hitch in the truck.
Checkout my site for RVing tips, tricks, and info | Was a Fulltime Family for 5 years, now we're settlin' down for a spell
Old 06-15-2018, 07:48 AM   #9
brookstone345sa's Avatar
Installed MorRyde and no more chucking or pushing. Hook up and go,don't have to worry about air. Been using for 6 years, no problems
brookstone345sa is offline   Reply With Quote
Old 06-15-2018, 09:27 AM   #10
florabama's Avatar
I opted not to get the Trail Air since I use the Andersen Ultimate hitch and I have an excellent ride. The road has to get very bad before I feel anything. My plan was to try without a dampening pin box but if the ride needed improvement I would have gone with the MorRyde.
2016 Ram 3500HD 6.7L CTD 4x4 CCSB
2017 CC 34RL2 Hathaway Edition
Andersen Ultimate 5th Wheel Hitch
Nights Camped: 2017=61
Nights Camped: 2018=25
Nights Camped: 2019=12 | Booked=6
florabama is offline   Reply With Quote
Old 06-15-2018, 10:05 AM   #11
W5CI's Avatar
I have the TrailAir and would not tow a 5er without it.
2005 Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2019 Days Camping 25
2020 Days Camping 7
W5CI is offline   Reply With Quote
Old 06-15-2018, 11:02 AM   #12
dieselguy's Avatar
I have the Fifth Airborne, a derivative of the Trail-Air mostly because I didn't want to stare at the shock mechanism right out front of everything. I had the Mor Ryde pin box with the rubber shear spring that came stock on my Montana. The Mor Ryde was a good step up from the standard pin boxes, but I like the Fifth Airborne way better. Someone mentioned it only moves a couple of inches, but that couple of inches makes a big difference. We're not off roading like dune buggies that require 8 - 10" of travel. It does reduce chucking, but doesn't eliminate it entirely … about the same as the Mor Ryde I had. Weight distribution (pin weight) and where the axles are positioned by design play a big role in how much chucking you experience.
dieselguy is offline   Reply With Quote
Old 06-16-2018, 11:24 PM   #13
I am recently new to the fifth wheel scene but not to RVís. I installed center point TrailAir suspension on my last trailer and loved it. I recently purchased a 34RL2. I ordered the trailer with the TrailAir pin box. The pin box works great. I believe it makes a big difference in the amount of weight transfer to the tow vehicle during braking and bumps in the road. Get one, you wonít be disappointed.
Fireman1 is offline   Reply With Quote
Old 07-12-2018, 08:43 AM   #14
Pin Box
Had the air right pin box installed yesterday. Drove about 8 miles from the RV dealer to my house and was very impressed with the difference. Looking forward to my trip out west in a couple of weeks for more smooth sailing
Old 07-12-2018, 08:55 AM   #15
BandJCarm's Avatar
Some interesting info on the Trail Air.
I had once since it was new. But I had the 18K (I think that means the 'donuts' are the 7 inch version). I had to put 133 lbs of air in it to get it above the arrows.
I had Orvan put in the bigger size (21K, which I think are 8 inch versions). Bingo! I only had to put in 84 lbs of air to get it to the right position. And it rides MUCH better.
Moral of the story.......don't assume because you have that brand, that it is the right size.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 07-12-2018, 01:29 PM   #16
I've got the Trailer Saver hitch in combination with a Mor-Ryde pin box and am very happy with them. Hitch takes care of vertical motion (seems to move about 3-4 in. up and down over a bad bump) and pin box takes care of horizontal motion. A pricey set-up but it seems to remove all chucking and makes for a smooth ride. Never have to add any air to the Trailer Saver but check the relationship of the white line to the hitch with every trip.
tomherb is offline   Reply With Quote
Old 07-12-2018, 02:38 PM   #17
x2
2016 RAM 3500 DRW 4x4 LB LoneStar Edition, w/Timbrens, Andersen Ultimate 2, Swift Hitch SH04 WiFi Backup/Rear View Camera
2018 Chaparral 360IBL w/TST-507 TPMS, Furrion Wireless Observation System, Progressive EMS-HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHU w/Andersen No-Sway hitch
chaps2018 is online now   Reply With Quote
Old 08-03-2018, 10:13 PM   #18
Pin box
Have traveled from Eastern Pennsylvania to grand Lake Colorado and then up to Blackfoot Idaho and now Iím on my way back. What a difference the air ride pin box made. And very satisfied
Old 08-04-2018, 10:13 AM   #19
Fifth Wheelers's Avatar
Been using the air ride with a B&W 24K hitch for two years. Works wonderful, hardly know the fifth wheel is behind me. Keep grease on the pin and hitch jaws helps a lot.
Best
Fifth Wheelers is offline   Reply With Quote
Old 08-07-2018, 06:27 PM   #20
SilverbackMel's Avatar
2015 Silverback. Trailair cushion. All over USA. Rides like a dream! ( a GOOD one )
Had std pinbox on 2012 Keystone. Went x country.
( great 5er) difference in movement is INCREDIBLE.
SilverbackMel is offline   Reply With Quote
