Old 09-30-2020, 10:37 PM   #21
GmanHawaii's Avatar
Look at Kipor, quiet like a honda half the price. Copied Honda. I've had mine for years, starts everytime.
2017 Ram 3500 DRW, 2018 41' Cedar Creek Silverback 37 FLK, 2005 30' Sandpiper
GmanHawaii is offline   Reply With Quote
Old 09-30-2020, 10:41 PM   #22
Yep. Honda EU3000is is goods it gets for 1 rooftop. Better with an easy start kit.
Running an AC with less will likely damage both AC and genset.
JRHERE is offline   Reply With Quote
Old 09-30-2020, 10:49 PM   #23
NMWildcat's Avatar
In my camping group there are a couple of folks who have installed the Soft Start on their 15k A/C and experimented with a single 2000k generator.
Yes, it will start and run the 15k and the TV, but not much else. If the battery is low and the converter goes into bulk mode while the compressor is running, it may overload the generator or least cause the TV and receiver to blink off.
And when the compressor is on, the generator is screaming regardless.
I love my two 2000s which I run in parallel when needing A/C. I run them both in eco mode and they are not at high rpm, so noise level is minimal.
And when not running the A/C, I just run one generator.
So yes, other advice is right on. A minimum of 3k. 3500 or more is even better. Even with a Soft Start.
Scott and Liz - Southern NM
Old 10-01-2020, 12:29 PM   #24
yetavon's Avatar
Originally Posted by TitanMike View Post
Something to consider.
My 3500 wat Champion sits on my rear bumper and runs there whenever I need it.
Ours has run complaint free 4 years now
2015 Shamrock 21DK
2005 Silverado Ext cab
Nights camped 2019.....all of Em...Homes a 2001 Sea Breeze 36' 5 ER
yetavon is offline   Reply With Quote
Old 10-01-2020, 12:35 PM   #25
Originally Posted by LasVagas View Post
Howdy ,
We have a 2019 Siilverback 35IK and we are looking to get a portable generator and have no knowledge what to get..Do we look at a generator vs an inverter generator and howv big do we need?? We have a residential fridge and maybe power one air conditioner.. Any direction would be helpful..
https://www.forestriverforums.com/fo...ew-217014.html
21wolfpupfq is offline   Reply With Quote
Old 10-01-2020, 01:43 PM   #26
bikendan's Avatar
Kipor was the first true low priced challenger to Honda and Yamaha, 15 years ago. But hardly anyone sells them anymore and there are much cheaper alternatives to even the Kipor. Like Champion and the HF Predator.
Old 10-01-2020, 02:44 PM   #27
wayne272's Avatar
Originally Posted by rsdata View Post
I wish I knew why he answered that way...
Can anybody else on this forum post that they can do this???
Yes, I installed the micro air soft starts on my 15k and 13.5k units and I can run both, lights and residential fridge on a 30a breaker with no issues.
wayne272 is offline   Reply With Quote
Old 10-01-2020, 03:07 PM   #28
rsdata's Avatar
good info to know about the 30A... probably not every 30A pedestal will do this I bet... often old breakers get weak and trip at way less than 30A
that clarifies the 30A pedestal issue, but that poster, 4garylee also said he did this with his 2200 genset, which does NOT sound like reality to me
2014 Shamrock 183
Old 10-01-2020, 04:07 PM   #29
wayne272's Avatar
I have never tried running on a generator (I do have 1 of the small generator inverter units, but it has never even had gas in it), always try to get FHU sites or at least water and electric, so I could not vouch for that. Nice if it does work though.
Old 10-01-2020, 04:24 PM   #30
Fully COVID-19 vaccinated
Just be sure to shut it off before using the microwave.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
timfromma is offline   Reply With Quote
Old 10-01-2020, 07:18 PM   #31
I have a power monitor in my TT that shows how many amps my 120 v system is drawing from the input as well as wattage.
When my 13,500 bty AC is running it draws a steady 11-12 amps. With soft start it draws 15-16 amps but since the meter is digital it may not be capturing the actual peak.
For ONE A/C unit that's just under 2,000 watts to start (maybe more) and just under 1500 watts running.
I'm with you, to run TWO A/C's on a 2200 watt generator does stretch the imagination. Unless the generator has a "fairy dust injector" on it.
As for running the TV, that's possible as most TV's today don't draw much more than 50 watts.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
generator
