Old 07-28-2021, 07:00 PM   #1
CampinGpa's Avatar
Pressure washer
I have a 2018 Cedar Creek Hathaway 34 rl2 does anybody use a pressure washer to wash the exterior of the fifth wheel and thanks for all the replies
CampinGpa is offline   Reply With Quote
Old 07-28-2021, 07:39 PM   #2
grumpyer's Avatar
Be careful,
don't get to close
2018 Flagstaff Super Lite 29RKWS
2015 F 150 max tow
Where ever you go there you are
grumpyer is offline   Reply With Quote
Old 07-28-2021, 08:11 PM   #3
Fiberglass skin or lap aluminum siding?
2019 F150 4X4 7050 GVWR 1903 payload
2018 Avenger 21RBS 7700 GVWR
Mike134 is offline   Reply With Quote
Old 07-28-2021, 08:23 PM   #4
CampinGpa's Avatar
Fiberglass and thanks for your reply
Old 07-28-2021, 08:24 PM   #5
CampinGpa's Avatar
That's what I was thinking maybe I should just use a brush
Old 07-28-2021, 08:48 PM   #6
I'd be concerned about the pressure washer, grit on the 5th wheel would "sand" if hit by a lot of pressure. A small error in nozzle distance could also be serious.
2021 2205S Rockwood Minilite
2019 F 150 Lariat 3.5 Eco Fx4 Max Tow
Equal-i-zer WDH, 1809 lb payload
flyflotrtim is offline   Reply With Quote
Old 07-28-2021, 09:21 PM   #7
bikendan's Avatar
I'd be be concerned pressure washing the caulking along the roof and the walls.
Old 07-28-2021, 09:23 PM   #8
I use a wide soft bristle brush on a telescoping pole.
2021 Cedar Creek Cottage 40CRS
Victron MultiPlus-II 12/3000/120-50 Solar installation
SacRV is offline   Reply With Quote
Old 07-28-2021, 09:24 PM   #9
CampinGpa's Avatar
Thank you well use my soft bristle brush I was not real hip on using a pressure washer anyways
Old 07-28-2021, 09:26 PM   #10
CampinGpa's Avatar
I believe that's what I will use was not real up to using a pressure washer but someone recommended it so I figured I would come out here and ask because you get excellent replies
Old 07-28-2021, 10:47 PM   #11
Let me add you’ll want to buy a extra wide bucket your brush will fit into.
Old 07-29-2021, 07:07 AM   #12
I use a power washer all the time, however I only use my blue and white tips or the foam cannon. I have placed my hand in front of both tips. The blue / soap tip has virtually no pressure, the white tip will turn my hand red but again the pressure is not that bad . That said just like going to a car wash that is pressure washer only I don’t feel like I get it clean. So I use white tip to knock of dirt, then foam cannon to foam then I scrub with brush. Followed by rinse with blue tip. I do the whole trailer this way, then when I think it’s clean I use foam cannon to foam the whole side with a soap and wax and now soap and ceramic, then go back to the front and rinse.
2022 Chevy 3500 Diesel SWD
2022 Columbus 329 DVC
moose074 is offline   Reply With Quote
pressure
