Old 08-21-2020, 11:37 PM   #1
Putty smears at interior staples
We have a 2020 Hathaway Edition 5th wheel.. Instead of using color matched fasteners to attach the wall and ceiling panels, they puttied every one. Badly. When you look down the walls and ceilings it looks like someone put putty on the palm of their hand and went ...staple...smear, staple, smear.
Dealer says every brand looks like that. I think he thinks we are stupid. Its our 4th trailer plus 2 diesel pusher motorhomes. We've never seen a putty smear.
Does yours look like that? Thanks!
PeteFuller is offline   Reply With Quote
Old 08-21-2020, 11:43 PM   #2
Not the same RV but mine is the same. It would have been less noticeable had they just left the tack heads alone.
flhtci2006 is offline   Reply With Quote
Old 08-22-2020, 07:33 AM   #3
Funengineer's Avatar
We have had this issue on each trailer weíve owned. I used paper towel to rub most of mine off.
TT: Flagstaff 25FBLS
Previous TT: Jayco, Rockwood and Flagstaff
TV: 2017 F-150 SCREW, 3.5L Ecoboost, 10 speed, 3.55, 7000# GVWR, tow package.
Funengineer is offline   Reply With Quote
Old 08-22-2020, 07:37 AM   #4
IchLiebeBier's Avatar
same here. ceiling and walls.
2019 Heritage Glen LTZ 272RL
2018 Ram 2500 CTD
IchLiebeBier is offline   Reply With Quote
Old 08-22-2020, 07:40 AM   #5
Kanadian Kamper
kenandterry's Avatar
...arenít they supposed to be that way?
Ken and Terry
2018 Sunseeker 2430S-CD
and if we ever need it, can be pushed by our 2017 GMC Terrain toad (4 wheels down)
Former Georgetown 330TS owner for 10 years with more mods than I can count.
kenandterry is offline   Reply With Quote
Old 08-22-2020, 07:43 AM   #6
Same way on ours. It's just sloppy application. I suggest wiping off the excess putty.
2020 Sunseeker 2440DS on 2019 Ford E-450, Trekker cap, Topaz paint
BehindBars is offline   Reply With Quote
Old 08-22-2020, 10:44 AM   #7
With what? It doesn't wipe off. And the dealer says there is no chemical that will dissolve the putty and not damage the walls and ceilings?
Old 08-22-2020, 11:07 AM   #8
NMWildcat's Avatar
Most RVs have this putty over staples that was just smeared on. On our current RV, you can only see it at certain angles.
You get used to it. And if you can't look past it, do like my friend, and paint the walls
Scott and Liz - Southern NM
Old 08-22-2020, 11:36 AM   #9
Misery loves company, I thought we had putty smears cause our TT is worth $. Guess you can spend $$$$ and get the same build quality.
2019 F150 4X4 7050 GVWR 1903 payload
2018 Avenger 21RBS 7700 GVWR
Mike134 is offline   Reply With Quote
Old 08-22-2020, 12:07 PM   #10
I used a paper towel and a little windex.
Sunseeker16 is offline   Reply With Quote
Old 08-22-2020, 02:22 PM   #11
Putty sloppy cleaning
Hay give it a little wipe up with a rag and WD 40. Used it for years!
Scubabear32 is offline   Reply With Quote
Old 08-22-2020, 04:49 PM   #12
ARLO
We have a flagstaff 8296fkss. You have to look hard to find ours.
rlocicero is offline   Reply With Quote
Old 08-22-2020, 04:51 PM   #13
I had the same issue with our Rockwood Mini Lite. It was easier to take care it myself rather than have the dealer fix. I just cleaned it off with an old terrycloth towel and some elbow grease.
Bev and Wynn, Iowa City, Iowa
2018 Rockwood Mini Lite 2511S
2015 Chevrolet 1500 LT, 5.3L, 3.42 gears
Iowa City Fix It is offline   Reply With Quote
Old 08-22-2020, 04:55 PM   #14
robo44's Avatar
2019 FR3 33DS Class A, Ditto, putty on every staple & nail..
2019 FR3 33DS Motorhome
650 Watts Solar, 400Ah LIFEPO4, 2000 Watt Inverter, 40A DC/DC Charger, SumoSprings, Roadmaster Steering Stabilizer, BlueOx Trac Bar, Truma AquaGo WH, NVIDIA Shield TV
Days Camping
2019 57:2020 20:2021 30 [/B]
robo44 is offline   Reply With Quote
Old 08-22-2020, 05:13 PM   #15
It probably looks OK when leaving the factory but after time passes and dust sticks to it the look gets more nasty.
Mineral spirits or citrus based Goof Off works if necessary.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 08-22-2020, 06:29 PM   #16
dieselguy's Avatar
1 Sportsmen, 3 Montana's, and now a CC Silverback ... all fivers had the putty smears if you looked just right say sideways to the walls. It grows on you after a while or ... the smears just got lost in my attention span ... I don't know which answer solved my attention to the smears.
dieselguy is offline   Reply With Quote
Old 08-22-2020, 06:48 PM   #17
Yeppers same thing on our trailer. Wife thought I was seeing things that weren't there.
Lots of time spent going over all panels. If you can't see it, you sure can feel it when rubbing the trim pieces.
Gary
Get out and have a good day on purpose cause everyday on this side of the grass is such a great time.
Nothing lasts forever, So live it up,laugh it off, take chances, & never have regrets, because at one point, everything you did was exactly what you wanted.
GlowPlug is offline   Reply With Quote
Old 08-23-2020, 11:10 AM   #18
I'm surprised, most time they say.
"That's how they make them now."
campers302 is offline   Reply With Quote
Old 08-23-2020, 12:56 PM   #19
X2
firemedicmark is offline   Reply With Quote
Old 08-24-2020, 06:18 PM   #20
rockfossilman's Avatar
Ours, too--solved in unique way!
Our Rockwood 2604ws had the same issue, but was most visible in the bedroom. We tried several methods to remove the mess to no avail. Eventually used a vertical stripe of camouflage-pattern duct tape down each seam in the bedroom--looks good and kind of makes the room look taller!
Rockfossilman - Western PA
Rockwood UL 2604ws - 2013 F150 w/MaxTow
"I'm a man, but I can change, if I have to. . .I guess."
Red Green
"Quando Omni Flunkus Moritati"
rockfossilman is offline   Reply With Quote
