Originally Posted by Redd1
2011 36rl hand some water under large starage belly pan wondering if there is a take their?
Water in the belly pan is not caused by your grey, black, or fresh water tank.
Start at the roof and look for leaks, then the 'marker lights, the windows and side walls. Then check the plumbing, look under the shower (access panel on near floor), check all the connections you can find for leaks. It is possible for the overflow from the fresh water tank to cause problems, but it's not common.
