Originally Posted by Total Bliss
Has anyone had any bad experiences with the ladder coming away from its supports. I am trying to figure if it is ok to put anything on it while traveling. Is it a warranty isue to attach something to the frame under the trailer for bikes and such.
Yes and NO how is that for answer!
Yes this is a warranty issue for the first or second year if you purchased the extended warranty. No after that it is your trailer and you can do anything you want to your trailer.
Now I have a 34RL Cedar Creek; the frame at the rear of my unit has two tubes weld on each side of the frame at the rear. These tube are for the bike carrier support, if ordered from the factory at time of build. I think you could drill some mounting holes for a bike carrier bracket on the neutral axis (center of tube) of these tubes for mounting a carrier. The bikes and bike carrier should weigh no more than 150LBS total.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
