Old 06-10-2020, 12:41 PM   #1
Shower door
Hi everyone
One of the rollers came off of the middle shower door (Picture attached)
Looking for advice or instructions to remove the doors to fix.
Thanks in advance.Click image for larger version
jmcclocklin is offline   Reply With Quote
Old 06-13-2020, 01:07 PM   #2
I believe there is one screw at each end of the top rail. After removing the screws, lift the rail straight up. The doors will lift with it. This is best done with a helper. Then, slide the doors out of the rail.
2012 Cedar Creek 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 06-13-2020, 04:20 PM   #3
Thank you. That's exactly what I did to fix the problem.
Old 06-13-2020, 10:35 PM   #4
CampinGpa's Avatar
It is very heavy. it happened to us
CampinGpa is offline   Reply With Quote
Old 06-13-2020, 10:39 PM   #5
Unfortunately after we finished fixing the door I thought...darn wished I put threadlock on the screw before I put it in!
Old 06-13-2020, 10:59 PM   #6
CampinGpa's Avatar
me tooo.but it is still tight if they come loose I will definitely have it
Old 10-18-2020, 04:08 PM   #7
Where did u find the new roller and did u replace them all?
bt_1959 is offline   Reply With Quote
door, show, shower
