Looks good. My DW uses Rain-X for Shower doors. We than use a squeegee on the shower door to wipe off the water after showering. Seems to keep the doors from water spotting.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
Recently took delivery of a new CC 40CL. Forest River changed up the shower doors from the clear glass to an opaque glass. You can't see the water spots with the new glass, but we still use a squeegee just because.
I use a chamois to wipe down the shower every time we use it. I wipe off the doors and the walls. I then hang the chamois outside to dry. This moves some of the moisture outside (cuts down on humidity in the RV) and also keeps the walls and doors clean.
Not a lot a work for a good deal of benefit.
Ben and Doreen
Never Enough Time Camping!!
Great idea on using the chamois. Hope you don't mind if I retire the squeegee and steal your idea?
Don't mind a bit.
Ben and Doreen
