Old 01-24-2018, 02:44 PM   #1
Shower Doors
I have the triple pane glass shower door in my 2017 33ik. I would like to remove the glass for cleaning and to apply some rainX. There has to be trick to this?? Help!
crrod is offline   Reply With Quote
Old 01-24-2018, 04:34 PM   #2
Always Learning
Iíve yet to read of a way to remove them. The most you can do is slide the 2 of the doors opposite and force your hand between them.
Checkout my site for RVing tips, tricks, and info | Was a Fulltime Family for 5 years, now we're settlin' down for a spell
ependydad is online now   Reply With Quote
Old 01-24-2018, 06:51 PM   #3
lesptr's Avatar
Shower Doors
If you do find the trick, please share. (I gave up and do what ependydad suggested)
2017 Coachman Chaparral 336TSIK
2015 F350 6.7
lesptr is online now   Reply With Quote
Old 01-24-2018, 07:21 PM   #4
GFAR's Avatar
Had the outside glass brake I am wondering myself on how to get new one in! The top track will not come out got new door coming on Friday! Will look at new out of the track maybe that will tell me something! Will let you know how it works!
GFAR is offline   Reply With Quote
Old 01-24-2018, 09:00 PM   #5
There must be a way, there was another post where the glass was taken out, cleaned, then sprayed with the frosted glass coating.
Rich5117 is offline   Reply With Quote
Old 01-27-2018, 03:24 PM   #6
Our solution (temporary) is the use of a tension rod with a plastic shower curtain inside the glass.
Kuppajoe is offline   Reply With Quote
Old 01-27-2018, 10:29 PM   #7
GFAR's Avatar
Got new shower door or should I say doors ( all 3 ) they are made as a set! Talk to tech at rv dealer there is no easy way to clean or put in new glass without taking top rail off and taking apart still 2 glasses on same track! He said it was faster and easy to replace all glasses instead of 1 it was no easy way to replace 1 glass! Thank goodness I have new so just take toprail off and put in new glass with the existing hardware that is already attached!
Old 01-27-2018, 10:43 PM   #8
There are a couple of small screws that hold the top rail to the side pieces. It's best if you have help. Lift up the top rail and the glass doors will come with it. I took mine into the bedroom, leaned them up against the wall and then slid the top rail off of the glass. We bought some stuff like window tint except it is green and has plant like designs on it. Now, the glass doors look great and we don't have to try to clean between the panes.
2012 Cedar Creek 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
Joe_GA is online now   Reply With Quote
Old 01-28-2018, 09:57 AM   #9
DKRITTER's Avatar
We have decided to allow ours to patina. I can say it's actually working pretty well.
Former Owner of
2016 Cedar Creek 36 POS (My Last FR Product)
DKRITTER is offline   Reply With Quote
Old 01-28-2018, 11:13 PM   #10
Big-Foot's Avatar
I got sick of wrestling with the glass to clean it. After the last cleaning, I installed a shower rod up above the top rail and now we pull a shower curtain in front of the glass.
Not very elegant, but I have not cleaned the glass in the last 3 months and it looks just fine....
Regards - Randy
Cedar Creek Cottage 40CFE
Thor Vegas 25.5
Randyís Rod Shop & Fabrication
Big-Foot is offline   Reply With Quote
Old 01-29-2018, 12:36 AM   #11
NMWildcat's Avatar
We use a squeegee after every shower. Glass still looks new........
Scott and Liz - Southern NM
Old 01-29-2018, 12:43 AM   #12
Big-Foot's Avatar
If you’re talking about the same triple-glazed shower doors we are, I’d really like to know how you squeegee the part of the glass that overlaps?
Really poor engineering to have installed the doors literally backwards from how they should be as it traps water and soap between the panels..
Regards - Randy
Thor Vegas 25.5
Old 01-29-2018, 12:49 AM   #13
NMWildcat's Avatar
The RV before this one had those aggravating doors. And yes, you can find a squeegee with a long thin blade with the handle in the center that you can get between the panels.
Old 01-29-2018, 10:14 AM   #14
Always Learning
If you're doing that, yank out the doors entirely and save yourself about 80 lbs. of weight.
As for us, we use a squeegee and shift the doors as we do each one. It doesn't get under but it gets close enough that it hasn't been an issue. And then periodically, my wife cleans the shower. Stays looking decent as she refused to switch to a shower curtain (even though we need that 80 lbs!).
Old 01-29-2018, 10:35 AM   #15
Jim34RL's Avatar
My wife cleans the doors a couple of times each camping season. We do squeegee the inside shower doors every time we shower, all three of the glass panes. My wife will clean the doors using "INVISBLE GLASS CLEANER" from Stoner. She did steal this from me out of the garage parts cabinet where I keep my cleaning products for the vehicles to clean them. We now use this for all of our glass cleaning needs such as mirrors and windows in the house too. She will also uses a tooth brush with paper towels to get between the doors and tracks to clean them.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 135K+miles
Old 01-29-2018, 11:30 AM   #16
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
As Joe GA said, the top rail comes off, a royal PITA though.
But, wouldn't it be more practical to wipe the whole shower down and not just the glass doors with a Shamwow?
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
Cypressloser is offline   Reply With Quote
Old 01-29-2018, 12:16 PM   #17
rracer5's Avatar
X2
I also Dremeled out the bottom slots flush on the track to allow ALL the water to drain out.
2014 Prime Time Sanibel 3250
rracer5 is offline   Reply With Quote
Old 01-29-2018, 12:24 PM   #18
Originally Posted by rracer5 View Post
X2
I did that also. I made the holes larger with a drill motor and they drain great.
Old 01-29-2018, 12:42 PM   #19
We do as well, but we can't get between the panes all the way to the edge. I want to take them apart to clean and Rainex.
Old 01-29-2018, 01:37 PM   #20
Big-Foot's Avatar
Our Cedar Creek is a Cottage and is semi-permanently moored in an RV resort so the 80# is fine.
Squeegee - no matter how thin - will not fit in the narrow gap between the glass.
We do squeegee and wipe down the shower after every use.
There are drain slots in the bottom guides so water trapping is not an issue.
door, show, shower
