Old 04-03-2018, 11:19 AM   #1
Shower faucet leaking under shower pan
I doth believe I performed a very poor winterization at the end of last season as it was my first on my new to us 2013 Silverback 39QB4. I used and blowout valve and thought I had done a proper job......
Upon first use of the season AND our first week-long trip in our new unit,
Both toilet valves leaked, replaced one, capped second until I get home.
Now when shower is turned on water pours out onto the floor beneath the shower pan.
There is a "pedestal" behind the faucet that it mounts to. The pedestal is mounted to the wall with 4 screws. I cannot locate a rear access panel as the living room wall/entertainment center mounted TV backs up to the shower faucet.
I removed the faucet knobs, valves and cover as well as the 4 pedestal screws but it did not loosen from the wall. The "pedestal" is caulked to the shower surround.
1) is it safe to cut the caulk and remove the pedestal?
2) does this seem to be the most likely access for removal of the faucet?
Any recommendations and expertise appreciated!!!
perrybpilot is offline   Reply With Quote
Old 04-03-2018, 11:33 AM   #2
I discovered a water leak behind the shower faucet pedestal/mount in my Freedom Express. Found it by opening the access panel at the bottom of the shower pan and saw water gathering on the floor under the shower pan. Removed the faucet pedestal/mount and found the water line to the faucet was loose from the factory install. I had to cut the sealing caulk to remove it from the shower wall. I was able to re-secure the pedestal/mount and caulk with clear caulk to reseal the pedestal.
2014 Ram 1500 HEMI Lone Star Edition
2018 Coachmen Freedom Express 248RBS
Roberte52 is offline   Reply With Quote
Old 04-29-2018, 02:11 PM   #3
New shower faucet assembly fixed the problem. It was cracked in the crossover line.
Old 04-29-2018, 02:16 PM   #4
SeaDog's Avatar
Thanks for getting back and letting the forum know what the problem was and the fix, consider RV antifreeze next year to eliminate the problems. JMHO
Retired Navy
2016 Flagstaff 26 FKWS
Old 04-29-2018, 04:59 PM   #5
Hutch333id's Avatar
I de-winterized my 2014 38FL this weekend and discovered what sounds to be the exact same problem - even though I had thoroughly winterized the rig. I discovered I had water leaking from under the shower floor while running fresh water through the lines, clearing the pink stuff. I then saw the water appeared to be running down the wall on the back side of the shower wall after looking through the access cupboard at the back of the heater. I ended up having to remove the mixer faucets from the shower and found the leak coming from an almost invisible crack in a black, T shaped valve that mixes both hot and cold water before forcing it up the flexible pipe to the shower head. Fortunately, we always start the season by camping at a golf/rv resort in the same town as the dealership, so I called in there, armed with the full faucet assembly, looking to purchase a new set. What I discovered, thanks to the service manager (off duty but buying gear for his own trailer) was the small black mixer valve could be purchased and switched out rather than having to spend nearly $50 on a new faucet set. In actual fact, he switched it out there and then for me and then didn't charge me the $4 for the valve. He said he could loose that cost quite easily. I took the original faucet with the new mixer valve back to the trailer and installed it back in to the shower without too much trouble - just a little tight working space with just enough room for fingers and a wrench to tighten the pipes back on the faucet assembly. Sealed it with some clear marine grade silicon sealant and tested her out. No leaks, drips or floods so now we're all good.
I did thoroughly winterize with RV antifreeze but this year we had prolonged periods down to -40oC (-40oF). The hard, plastic mixer pipe/valve still split, even with this fluid having been run through.
Here is a link to the faucet set I have. The cracked plastic mixer tube/valve is behind the nickel coloured cover but attached to the small, black threaded piece in the centre. This piece is what attaches to the flexible shower hose.
https://www.makariosrv.com/american-...ve-x-ynn53vbn/
Richard & Diane
2014 Cedar Creek 38FL
2016 F350 Lariat CC DRW
Retired Metropolitan Police (UK)
Hutch333id is offline   Reply With Quote
faucet, leak, show, shower
