I have a 2010 Cedar Creek Cottage. The 50 amp breaker tripped at the tongue near the battery. Now the slides do not work. The Solonoid clicks so I replaced it to see if that was the issue. Now nothing happens. I have 13.4 V at the battery, same voltage going thru the breaker. 13.4 volts at the pump/ solonoid. 13.4 volts at the toggle switch. When I push the button nothing happens. I use a drill to close slides. Any suggestions to get them working on the 12 volt system. Am I not seeing another breaker?
The next step will be the switch. However there is a switch near the pump and another in the coach. Could both be bad. If I touch the wires together the motor should turn? I am trying one thing at a time. I will try your suggestion. Thanks
