Old 12-21-2020, 12:47 PM   #1
wls
solar
I have a 2016 38FB2 CC, and was wondering if anyone had solar installed on their coach? Especially the FB2 like I have, but all answers are welcome. Thanks
2008 Dodge 3500 Dually, Cummins. Amsoil Bypass Oil Filter, 36 Gal aux fuel tank. Mag Hytec Trans pan. Mag Hytec Diff Pan. 6 speed autostick. 3:73, Timbrens, Smarty JR. Equipped.
2016 Cedar Creek 38FB2
2016 Camping Days=38
2017 Camping Days=24
wls is offline   Reply With Quote
Old 12-21-2020, 01:41 PM   #2
I guess I do not count.
From an engineering perspective we choose not to install solar. CC 34RE, Another couples trailer.
Every situation is different.
Do you want a panel to charge the batteries in the winter, or provide battery recharging while boondocking so as to never run a generator?
Or somewhere in between. $500 & $15,000.
Come hell or high water we can go 48 hours disconnected. We have 4 GC2 batteries and a Honda 2200 generator.
tomkatb is offline   Reply With Quote
Old 12-21-2020, 06:14 PM   #3
wls
I dont think I need a big system, talked to a installer in Shipshewana, 3-210 panels and 4 batteries. I do have a 3500 gen, and 2 deep cell batteries currently. I guess something to maybe boondock for a couple days, and maybe assist when I get to a site where I have to pay for the electric. I do have a residential refrigerator also.
I'm still throwing it around, just looking for feedback, Thanks
Old 12-21-2020, 07:16 PM   #4
630 watts of solar gets you about 150 amps on its best day.
The issue with the residential fridge is they use a lot of juice. The inverter alone consumes 1 or 2 amps per hour. Most inverters have a 15-20% power loss in the conversion.
4 GC2 batteries as I have available are 210 amps.
4 lithium would be better. 400 amps.
Get a good battery monitor. Since I own no solar we have a WiFi voltmeter.
The Vitron would be better.
We live in the Midwest. Boondocking is pretty limited. Our speciality is older state and federal parks with 30 amp service. We can easily go 7 days without hookups.
Old 12-21-2020, 07:27 PM   #5
If you wanted to hang out for a week or more off grid, what generator would you suggest. I have a single 2000 and Im told a second unit will really up the power.
LB
Leadbouncer is offline   Reply With Quote
Old 12-21-2020, 07:48 PM   #6
Almost all inverter generators can be paralleled. I. E. 2 of them give you about 30 amps! Usually a $30-40 wire kit.
You could carefully run any appliance. My DW is a master at not tripping breakers.
We carry only one. Will add an easy start to run one ac unit. Likely we will never use the ac.
Old 12-21-2020, 08:49 PM   #7
wls
I'm thinking of adding an easy start on one of the AC's.
Like I said just tossing it out whether to spend on solar. I have also thought of 4 batteries, and keeping the 3500 kipor inverter gen, or getting a 2200, much lighter.
Old 12-21-2020, 08:56 PM   #8
Check out Long Long Honeymoon on YouTube - they have a video on how they setup their solar on their AirStream - they spent $16k on their setup.
I also so a video on YT, I don't recall the channel name, the guy ran his 2k portable gen with a 6 gallon tank for about 40 hours straight, which included running his AC.
2021 FR Evo T2460.
TV 2018 Ram 1500
Sacramento, CA
Days Camped:2021 - 21
evorv is offline   Reply With Quote
Old 12-22-2020, 11:27 AM   #9
LittleBill's Avatar
I have boondocked in my TT with a 2200 inverter mainly to keep batteries charged. I have a CPAP and need to make sure it will last through the night. The inverter will run 6-7 hours on a tank of gas with no A/C or microwave, so it is running basically 12V stuff at idle the whole time.
Also on my 5er I had Orvin add easy starts to both A/C's so I can run them if needed with the 2200 inverter
2018 Cedar Creek 36CK2 (40.5ft)
TST Cap System (Tire Monitoring)
2021 Chevy 3500HD Crew Cab 4X4 DRW Duramax (replaced 2015 Chevy 2500HD Crew Cab 4X4 Duramax)
Curt A25 5th Wheel Hitch (replaced Demco 18K Auto-slide)
LittleBill is offline   Reply With Quote
Old 12-22-2020, 11:31 AM   #10
Would that be an inverter generator?
- 2016 Ford F-150 SCrew Lariat RWD MaxTow
- 2020 Rockwood 2507S
chriscowles is offline   Reply With Quote
Old 12-22-2020, 11:47 AM   #11
LittleBill's Avatar
Yes. I have a Roybi 2200 that I got at Home Depot a few years ago when my 3500 generator was giving me some trouble. I would like to buy a second 2200 so I can parallel it to the first one. Thus I don't have to man-handle the 3500 into the back of the truck. Haven't pull that plug yet.
They no longer make the 2200 I have as they have upgraded the technology (and price). Here is one in the same category but with more stuff on it than mine that they sell now - https://www.homedepot.com/p/RYOBI-2-...E&gclsrc=aw.ds
A lot of those on the forum here are looking at what Harbor Freight has as they seem to be lower in price than most other places.
solar
