Old 04-08-2016, 09:51 PM   #21
We had the intermittent brakes happen on the trailer. Sometimes they would work, sometimes not. Ended up being the plug on the brake pedal had a broken wire in the connector. Changed the connector that plug into the pedal, everything worked. apparently it was a common thing on '05 gm's.
dbryan79 is offline   Reply With Quote
Old 04-08-2016, 10:11 PM   #22
Little reaction from the OP ( thanks guy's tried that/checked this and that)So why ask? Lot's of good info from the forum. I'm out!
mike.t is offline   Reply With Quote
