11-01-2018, 04:45 PM
Strange battery/power issues
2013 36CKTS. everything has been good for awhile. I recently replaced both battery’s from Costco. We are camping now. What seems to be happening is everything will be fine, until we unhook power to go dump, reconnect power and later find the one of the two 40amp polarity fuses to be blown. I’ve replaced one once and the other twice. All the power seems to be good. We’ve ran the AC and other devices and they all work. I just now keep checking the battery charge status at the control panel, and I will see the batteries not reading full and that tells me one of the fuses is blown. So the question is, what is blowing the 40amp fuses? According to the manual it will only blow for reverse polarity. I know the red to going to the positive and the Black is going to the negative, so what else could it be?
Any thought?
Greg
Truck: 2015 F350 Platinum
Trailer: 2013 Cedar Creek 36CKTS
11-01-2018, 05:51 PM
Are the batteries hooked up in parallel or in series?
2019.5 Rockwood 2509S
11-01-2018, 05:54 PM
What ever is standard. Red from the trailer is going the one positive terminal, then that goes to the other battery positive terminal. Same for the nagative
11-01-2018, 05:55 PM
Occasionally if you have lots of stuff running on 12V side of RV the battery will deplete and when reconnected to shore power, this inrush of current into the battery will blow the fuse. Also just for kicks, check the break-away switch to insure the pin is not pulled.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
11-01-2018, 05:58 PM
Are they 12 volt or 6 volt batteries?
When you unplug from shore power do the batteries stay charged?
Have you tested the battery voltage when the batteries been have been disconnected for a few hours?
It sounds like you may have gotten a bad battery.
Gotta go campin!
11-01-2018, 06:08 PM
What is the breakaway switch? Where is that located?
11-01-2018, 06:09 PM
12volt batteries. I have not checked them after awhile. Will do that
Greg
11-01-2018, 06:15 PM
Break-away switch is the pin that is inserted into the switch that has the small wire cable that is connected to the TV in case the trailer is separated from the TV it will apply the brakes, Usually mounted on the frame near the hitch.
TST Tire Monitors
2 100W solar panels
11-01-2018, 06:24 PM
After you check the Break-Away switch like Flybob suggested, you should have the batteries load tested to make sure they're good.
Gotta go campin!
11-01-2018, 06:34 PM
A note on "Load testing" deep cycle batteries. It's a good idea to go to an actual battery store to have this done rather than an Auto Parts chain store.
The "testers" used at many A/P stores are not able to give a true test of a deep cycle battery. They're pretty much designed to be a "no brainer" for testing automotive starting batteries. The large battery only stores will have more knowledgeable people and better equipment to do the job.
Most areas have at least an Interstate Battery Center and they are pretty reliable for testing.
11-01-2018, 06:37 PM
Just for future ref. AC and other devices are 120 volts and not related to your battery.
11-01-2018, 07:06 PM
Be careful with "What ever is standard..." since not all units are "standard". I had one unit with a white ground (negative) cable and a black positive.
11-01-2018, 07:29 PM
Just as confused as you
X2, Both of my cables are white with yellow terminals, the positive cable has 2 inches of black electrical tape wrapped around it.
Richard & Jill
11-01-2018, 07:36 PM
I'm Lost
Good advice Mike
Geoff
Geoff, Francesca and Lucy the Golden holy terror (I mean retriever, BD Nov. 2018)
2023 F150 Screw, 3.5L, HDPP, LT tyres.
2013 Rockwood Signature 8310SS
2023 F150 Lariat 502A (After all rebates, price protection and dealer discounts, I saved $12,600Cdn. (Cavalcade Ford). If pays to shop dealers! (April 2023)
11-01-2018, 07:38 PM
Need to have someone verify your batteries are wired/installed correctly. Usually there is a drawing stuck to the battery compartment door, but your rig could be different.
Assuming you have two 12v batteries which is what most CC come with?
2016 Ram 3500HD 6.7L CTD 4x4 CCSB
2017 CC 34RL2 Hathaway Edition
Andersen Ultimate 5th Wheel Hitch
Nights Camped: 2017=61
Nights Camped: 2018=25
Nights Camped: 2019=12 | Booked=6
11-01-2018, 07:40 PM
CC (or most any other) doesn't come with batteries. Dealer installs. If you order it, you get what you ordered. If you buy off the lot, you get what's in there unless you negotiate otherwise. There is no standard, other than it has one 12v battery at a minimum.
FROG AR-0019-242
11-01-2018, 07:45 PM
You are correct in that it may very but they come from the factory with a recommendation of two 12v batteries, what the dealer or new owner does is totally different.
Just trying to get the OP to provide more specifics.
11-01-2018, 07:53 PM
Yes. Good point. Need to know his layout. The diagram is on inside of my battery compartment door, and it shows 2 batteries, even though I have four 6v's.
My bad, you are more correct
FROG AR-0019-242
11-01-2018, 09:07 PM
The batteries are connected the same now as they were we picked up the trailer 5 years ago. Never had a problem before, Just new batteries now
Will check it all tomorrow and report back
Greg
