Originally Posted by richp
Hi,
I eluded this problem by permanently attaching a short piece of hose to this fitting. It's maybe 5 feet long, and the longer hose from the water supply attaches to it well outside the compartment.
I never have to unattach the hose at this location, and any dripping from the flush operation can happen when I let the hose drape down outside the compartment for a minute or two.
To facilitate storage, I attached a broom clamp on the side wall, and the free end of the short hose bends up and clips into that.
FWIW.
Rich Phillips
I did a similar thing upon a recommendation from Orvan. I have (2) 4 foot 5/8" hoses (different colors) that I leave attached to the fresh water and black tank flush connections using 90 degree elbows. I feed the hoses thru the access hole and attach them to my supply hoses below my unit that I connect to the spigot. Thus when I disconnect them, the water runs out onto the ground rather then inside the unit. I also have a shutoff valve between the black flush connection and the 4 foot hose so I can quickly shutoff water when using the black flush. I leave them on all the time and just curl them up inside the control compartment after they have drained, thus no water in the compartment. I also have quick disconnects on the hoses where I connect the supply hose.
This is the hose I got for the fresh water connection -
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
This is the hose I got for my black flush connection -
And this is the quick connect I ordered from Home Depot -
https://www.homedepot.com/p/Melnor-2...5411/309634277
I would supply a picture but my unit is at Orvan's for some work.
2018 Cedar Creek 36CK2 (40.5ft)
TST Cap System (Tire Monitoring)
2021 Chevy 3500HD Crew Cab 4X4 DRW Duramax (replaced 2015 Chevy 2500HD Crew Cab 4X4 Duramax)
Curt A25 5th Wheel Hitch (replaced Demco 18K Auto-slide)
