Originally Posted by DeanV
Anyone have any experience or opinions about the Roadmaster Comfort Ride slipper springs/shock absorbers? After watching the video from the manufacturer, I am impressed by the engineering. Kind of a poor man's independent suspension. Looks like a decent shade tree mechanic with the right tools could easily handle the install.
This past summer, I installed on our 5'er the Roadmaster Comfort Ride shocks and replaced the factory installed equalizers and shackles with LCI's Road Armor kit. Both upgrades, along with the MorRyde Rubber Pin box upgrade I did myself too have made a major improvement in the ride quality and towing experience. Much smoother and noticeably less bumpy.
There are two or three good content videos for how to do the installation. Two are from eTrailer, one on YouTube and the other on eTrailer's web site. As you've already discovered, as long as you've got the right tools, its a relatively easy upgrade to do yourself.
Now, there're three things you need to be aware of they don't tell you in the installation instructions for the shocks. First, you CANNOT install the shocks upper frame brackets to a tubular RV frame with the provided self tapping screws. It requires an I-beam frame to install them. My 5'er had a tubular frame rail welded to the I-beam frame where the equalizer hangers were. I had to pay a professional welder to install the upper frame brackets to the tubular frame rail. Worked perfectly.
Second, you'll likely need to replace the U-bolts attaching the axles to the Roadmaster tie plates. Because the tie plates are so much thicker than the tie plates from the factory, the factory U-bolts won't be long enough to install. You should see at least a couple inches of the bolt threads once you put the tie plates in place. I bought two, longer replacement U-bolt kits on Amazon. Each kit comes with four U-bolts and nuts, but don't forget like I did that you need two U-bolts per tie plate. Initially thought one kit would do the trick for a dual axle install.
Lastly, carefully check the area around the frame where the equalizers are for any propane, brake or sewer lines that're installed. I had a sewer line that obstructed the area where the shocks on the drivers side were bolted to the frame. I had to cut out a three or four foot section of that line and re-route it away from the drivers side a couple of feet with some PVC elbows and pipe from Home Depot.
