Old 09-01-2021, 07:13 PM   #1
Tail lights not working on one side
We have a 2016 Cedar Creek 33IK. The passenger rear tail lights do not work when braking or signaling a right turn. We replaced the two oval lights but still not working. BUT, when we turned on the truck headlights, the lights worked. All other lights work all the time. Any ideas what to do next?
lesteph1520 is offline   Reply With Quote
Old 09-02-2021, 12:45 AM   #2
LittleBill's Avatar
You don't mention whether or not the truck tail/brake/turn signal lights work or not. If they don't then you may have a bad turn signal relay. Does the 5er's tail light work at all? If it is only one bulb that does both tail light/brake light/turn signal the filament in the bulb for the brake light/turn signal could be bad. Try swapping the bulbs out with the driver side and see if that works. If the passenger bulb works/doesn't work on the driver side then you have somewhere to start.
The connection/wiring to the passenger side could be corroded/loose at the light or somewhere in the wiring harness. Lots of possibilities as to the specific problem, you will have to investigate, back track and eliminate them one by one.
Good luck and be safe -
2018 Cedar Creek 36CK2 (40.5ft)
TST Cap System (Tire Monitoring)
2021 Chevy 3500HD Crew Cab 4X4 DRW Duramax (replaced 2015 Chevy 2500HD Crew Cab 4X4 Duramax)
Curt A25 5th Wheel Hitch (replaced Demco 18K Auto-slide)
LittleBill is offline   Reply With Quote
Old 09-02-2021, 03:17 PM   #3
We got it solved!! It turns out there are fuses in the truck under the hood that are for the trailer lights...who knew?! (One service person we called said if all the other lights worked, it wasn't a fuse....so we didn't pursue that line anymore.) We replaced a small red 10 amp fuse under the truck hood and voila, we had turn/brake lights on the trailer. (The truck lights always did work.) We are very happy campers now.
Old 09-02-2021, 03:46 PM   #4
I can't speak for other manufacturers but Ford has been using separate fuses for the 7 pin connections for decades.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 09-02-2021, 03:52 PM   #5
Mr. Dan's Avatar
Who knew? I did but I didn't get a look at your original post or I would have helped.
My GMC blew the same red 10a fuse for one of trailer's tail lights.
Old 09-02-2021, 04:07 PM   #6
I only knew because I found out the same way the OP did, just a few months ago.
2021 Flagstaff 21DS
2015 Silverado 2500HD (overkill but convenient)
Renogy bits: 3000W Inverter/Charger, 400Ah LiFePo4, 40A DC-to-DC
Rich Solar bits: 400W of panels, 40A MPPT
Misc bits: LevelMatePro+, SolidRemote based wireless controlled LED storage lighting
jbflag21ds is offline   Reply With Quote
Old 09-02-2021, 05:41 PM   #7
LittleBill's Avatar
I had forgotten that a fuse might have blown. On my previous TV I had the 30A fuse that sends power to your unit blow. The service guys at the RV dealership helped me find out that it was blown when I couldn't operate the RV's jacks when connected to the TV. It happened a couple of times where I ended up by buying a pack of 10 on Amazon.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Be safe -
Old 09-02-2021, 05:59 PM   #8
lesptr's Avatar
I’m glad you found the problem.
I had the same problem.
It turned out to be the pigtail that connected to the 7pin on the bumper to the 7 pin connector in the bed. I replaced that wiring harness and have had no problems since. (I also replaced one tail light assembly on the 5r, which solved the problem for about an hour). Maybe I should up my trouble shooting skills.
2017 Coachman Chaparral 336TSIK
2015 F350 6.7
lesptr is offline   Reply With Quote
Old 09-03-2021, 06:37 AM   #9
We also have a GMC. Do you know WHY it blew?
Old 09-03-2021, 06:51 PM   #10
The Newsoms's Avatar
Our blows the fuse every time we tow.
Jimmy & Teresa Newsom
2018 Riverstone 38RE/2019 Sundowner Toyhauler
2020 RAM 3500 SRW
The Newsoms is offline   Reply With Quote
light
