Old 09-20-2018, 10:44 AM   #21
Stevemc's Avatar
If the tank heater is on, the water in the tank works as a conductant to keep the water in the tank above freezing. Wouldn't this conductive action also extend to the water that is in the drain line between the tank and valve? The only freezing problem should be if there is water in the drain line past the shut off valve.
Steve & Jean
Furbaby - T.J. RIP
Towmotor - 2013 Chevy LT DRW Duramax/Allison
5er - 2013 Cedar Creek 36CKTS Classic Champagne Touring Edition
Stevemc is offline   Reply With Quote
Old 09-20-2018, 12:16 PM   #22
nomad297's Avatar
I guess it all depends on how cold it is.
Bruce
nomad297 is online now   Reply With Quote
Old 09-20-2018, 12:32 PM   #23
I just got back from Lowes with a roll of R-19 unfaced insulation. I have to replace the stuff that got wet and I'm going to add more. Especially, around the drain pipes.
2012 Cedar Creek 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
Joe_GA is online now   Reply With Quote
Old 09-20-2018, 02:16 PM   #24
My grey water valve was below the tank with about a four foot piece of schedule 40, had the drain line been schedule 80 the line may not have busted, the valve has thicker walls and it didnít burst only the drain line. The drain line was touching the frame so that may have caused the drain line to burst. On the new Cedar Creek this May have been changed. My Creek was built in 2014
spock123 is offline   Reply With Quote
Old 09-20-2018, 02:21 PM   #25
nomad297's Avatar
Schedule 80 would have split just as easily as the schedule 40 if it had frozen solid.
Bruce
Old 09-21-2018, 05:01 AM   #26
nomad297's Avatar
To be clear, my post refers to the low point cold and hot water drain lines. Not the waste water drains.
Thank you for the clarification ó i need to brush up on my reading comprehension skills. It would be ideal to have the valves for the low point drains like you do. It should be pretty easy to do this with a fifth wheel, with all of the water lines above the basement, but I think it would be difficult to do with most travel trailers since there is not much room to play with between the inside heated area and the underside.
Bruce
heater, tank
