Old 12-27-2017, 10:26 PM   #1
tank heating pads on CC 34RL2
So far have had no problem with unit but just keep forgetting to ask this question. How do the heating pads work on this unit. Do they come on automatically when temps go down and unit is plugged in? Is there a switch I don't know about. Just now having very cold temps where I am and got to thinking about this issue. I drained all low point drains etc. Just wondering.
Thanks for any help.
hollandsam is offline   Reply With Quote
Old 12-27-2017, 11:06 PM   #2
Should be a switch on your control panel. When you turn it on, it supplies power to the heating pads.
The pads have internal temperature switches that then turn them on and off. As I understand it, they turn on around 42 deg and off around 65 deg,
2011 Traverse LT, 3.6L, FWD
Old 12-28-2017, 08:57 AM   #3
florabama's Avatar
Ditto above. My 34RL2 has a switch on the control panel.
2016 Ram 3500HD 6.7L CTD 4x4 CCSB
2017 CC 34RL2 Hathaway Edition
Andersen Ultimate 5th Wheel Hitch
Nights Camped: 2017=61
Nights Camped: 2018=25
Nights Camped: 2019=12 | Booked=6
florabama is offline   Reply With Quote
Old 12-29-2017, 08:38 AM   #4
Same here, switch on CP, I thought I read they come on if it falls below 50F but not 100% on that data point.
Don
US Army Infantry Retired
Texas Hill Country
Cedar Creek Silverback 29RE
'19 F 350 CC, LB King Ranch Ultimate
17 Oaks is offline   Reply With Quote
Old 12-31-2017, 11:41 AM   #5
sh1pper's Avatar
If your water tank is drained, can you still use heating pads?
Hugh and Fran
"Riley" the dog
2018 Cedar Creek 38EL Champagne
2017 Ford F350 SRW CC SWB 4x2
Demco Hijacker Autoslide 18k Hitch
sh1pper is offline   Reply With Quote
Old 12-31-2017, 12:33 PM   #6
dieselguy's Avatar
Hugh & Fran ... the Ultraheat website actually states to use the heaters only when there is fluid in the tank... just wondering ... if your tank is empty, why turn on the heat pad anyways?
dieselguy is offline   Reply With Quote
Old 12-31-2017, 06:42 PM   #7
sh1pper's Avatar
I assumed the heat pads were also on the grey and black tanks. Are they only for the water tank?
Hugh and Fran
"Riley" the dog
Old 12-31-2017, 06:59 PM   #8
?X2
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
mwdilday is offline   Reply With Quote
Old 12-31-2017, 08:45 PM   #9
dieselguy's Avatar
4 tanks ... 4 heat pads. Unfortunately (at least on mine) all 4 activate off one switch. I always dump all 3 at the same time, so guess I never thought of it where one would be empty and the others had some fluid. Shagrin is on my face ...
Old 12-31-2017, 09:44 PM   #10
rracer5's Avatar
4 tanks, 4 pads, 2 switches on mine. I think my literature says they kick on at 40 degrees or below.
Oh, and my switches are not labeled so, I don't know which 2 tanks each switch controls.
2014 Prime Time Sanibel 3250
rracer5 is offline   Reply With Quote
heating, tank
