Old 11-29-2018, 08:50 PM   #21
SilhouettePenny's Avatar
Originally Posted by 05CrewDually View Post
Sounds like you need shocks on the trailer. For curtains to be falling it has too much bounce in the springs. TrailAir pinbox cushions the bounce between the truck and trailer so it won't help much for bouncy leaf springs. But shocks will by dampening the bounce.
Bounce is definitely an issue, especially with 110 PSI tire pressure. I'm contemplating a suspension upgrade to include shocks.
2017 F350 Dually 6.7
2019.5 Hathaway
He who dies with the most tools, wins!
SilhouettePenny is offline   Reply With Quote
Old 11-29-2018, 08:55 PM   #22
2007 WildCat 32QBBS
18CrewDually's Avatar
I always considered adding shocks but we just don't get all that much bounce, atleast that I can tell.
I wish I had the link but there is a video on youtube of a trailer's undercarriage and suspension & you would not believe the movement and oscillation of the shackles. Almost sickening. Shocks have to help.
18CrewDually is offline   Reply With Quote
Old 11-29-2018, 09:45 PM   #23
....you would not believe the movement and oscillation of the shackles. Almost sickening.
Yes sir, I saw that video. That's why I started researching suspension upgrades. As fast as that equalizer was bucking it's no wonder the bushings wear out so fast.
Isolating the axles from each other eliminates the equalizer. So the Liberty Rider slipper spring system has caught my attention.
I'm aware of the Timbren axleless devices but still willing to stay with leaf springs on my 7K axles.
2019.5 Hathaway
Old 11-29-2018, 10:09 PM   #24
2007 WildCat 32QBBS
Yes! That's the video. I have I'll equipped 2600# springs but considering swapping in 3500 springs and shocks. The old springs are starting to flatten out a bit.
The ultimate ride I think would be an independent, maybe torsion, with shocks and disk brakes. Eh, maybe on the next 5er we will get that.
With all that said, I do love the Trailair. Just watching that adjusting to the bumps going down the road is enough to know it's doing something. About 65 psi is good for me. Plus about 10psi in the airlift airbags and it rides smooth.
Old 11-30-2018, 08:36 AM   #25
Originally Posted by LegacyFB38 View Post
110 PSI may be too high.
For example, if you have roughly 12,000# on the RV axles...or about 3,000# on each tire, the tire load chart may very well call for less pressure.
I have dropped the air pressure down to one hundred psi and still canít tell any difference. I may try the Goodyear Endurance next time
spock123 is offline   Reply With Quote
Old 11-30-2018, 10:34 PM   #26
100 psi MAY still be significantly high.
The load chart will give a really good idea of the proper pressure for your specific tires with your loading. Ideally, weigh the rig to get the actual axle weights.
2017 Riverstone 38FB Legacy
2018 F450
LegacyFB38 is offline   Reply With Quote
Old 12-04-2018, 09:21 PM   #27
BandJCarm's Avatar
I had to go over 100 psi on originally installed 18,000 lb. Trailair, to hit the arrows correctly. And it was so tight it wasn't doing what it was supposed to do. So I had the next biggest size bladders installed, the ones that go on the 21,000 lb. model, and it made a world of difference. I hit 93 lbs and it's perfect.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 12-07-2018, 06:39 PM   #28
I've noticed the trailair bladder is bigger on our 2019 CC 34RL2 than what was on our 2009 32 WRL Silverback. Last time I measured the bag was 90PSI and very near the arrow mark.
I do need to add air every few weeks.
Liked the first one which is why we made sure our new trailer has it.
Mike K
2019 Cedar Creek 34RL2 w/disc brakes
2017 GMC 3500 D/A, DRW, 40Gal Aux Tank
USN 76-82
Retired Dept of Navy: Navy/USMC Flt Test Engineer
Splashes3 is offline   Reply With Quote
Old 12-08-2018, 12:55 AM   #29
2007 WildCat 32QBBS
They offer 2 sizes, an 18k and a 21k pound unit. You must have the 21k on the new 5er.
https://store.lci1.com/air-ride-pin-box-trailair
https://store.lci1.com/flex-air-by-trail-air
