09-25-2017, 06:08 PM
Travelling using gas for fridge
Anyone have trouble with fridge pin had during travel? Mine only works party of the time. I made sure air was out of line and was working before rolling out. Still had problems and had to reset once reconnected to power.
09-25-2017, 06:11 PM
I would usually purge the line by lighting the stove, this always helped me.
09-25-2017, 06:12 PM
Always do that. Still have problems
09-25-2017, 06:13 PM
I'm thinking about taking it apart and going it a good cleaning. Your thoughts?
09-25-2017, 06:39 PM
When you disconnect from the AC power do you hear it clicking to light it?
40 years in RV's and honestly I have never had a fridge problem.
I unhook the shore power and listen for it to light and go on my way.
Mark B.
2021 GMC 1500
Anderson WDH
09-26-2017, 06:36 AM
Just thinking out loud but how good is the 12 volt?
09-26-2017, 11:01 AM
I wait and listen for it to light and the LP light on panel to light up. Batteries are new and fully charged. I think I will clean the burner jet.
09-26-2017, 01:28 PM
The gas portion of the refrigerator uses a Bunsen burner style arrangement. The mixing of gas and air in the tube to the flame is easily disrupted by bugs and their webs, etc., so I'd check and ensure the tubes are clean.
2015 Wildcat 282 RKX
2011 F350 Lariat, 6.7 L. Diesel, 8 ft., SRW, Reese R20
09-26-2017, 01:33 PM
Will do. I've been seeing a few stink bugs around. Going to tackle this beast tomorrow. I appreciate everyone's input.
09-26-2017, 01:44 PM
Just A Member
We had trouble for the last six months. Sounds identical to your problem. It ended up being the propane regulator / control at the bottles on the front of trailer. It finally quit working entirely. Replaced regulator and the refrigerator now works fine.
09-26-2017, 03:11 PM
The ONLY trouble we have ever had was after connecting to the park electric there was one instance where the refer stayed on Gas, even though it was in the Auto mode. Turned it off back on and problem was corrected. It has never happened again. I guess my gremlin died.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
09-26-2017, 05:05 PM
New regulator here. Can you send me specifications on the one you bought? Thank you
09-26-2017, 05:31 PM
Just A Member
Here is a link to the one that I used.
https://www.amazon.com/Fairview-Prop...pane+regulator
Fairview two stage automatic changeover regulator. There are several makes and they are different sizes and mounts. Look at the one you have and either duplicate or get close to the size and mount so you don't have clearance problems. I don't know if one brand is better than the other. Someone else might have an opinion.
09-26-2017, 05:54 PM
Thank you. I ordered one since the one I bought was only 210k btu. Sounds like that is the culprit. Holding off on cleaning until I switch out the regulator.
09-26-2017, 06:32 PM
We have repaired many where the burner was actually covered with a little pile of rust from the chimney. Just remove the burner cover (one phillips screw usually) and blow off the burner then light it and see how the flame looks, it is only a small flame and should be mostly blue if it is working correctly.
Retired Auto body teacher
2021 Arctic Wolf 3550 Suite
2019 F-250 Lariat Super Crew 6.2
Having lots of Fun traveling with my wife
09-26-2017, 09:59 PM
HikerBob
I always turn the fridge off after disconnecting from shore power, then turn it back on, as that resets it's internal thinking. Then I release the GAS button and listen for a few minutes to be sure it lights. I think you've received a couple good suggestions from others here, so good luck.
09-26-2017, 11:19 PM
Exactly!! X2
Floyd & Carolyn
2012 F150 S/crew 4X4 6.2L 6Spd Tow Max Firestone airbags. 2011 28RKS Wildcat. Yamaha 3000iseb Gen.
2014 57 nights.2015 116 nights .2016 96 nights .2017 72 nights. 2018 157 nights. 2019 52nights.2020/21 118 nights. 2022 115nights
09-27-2017, 11:40 AM
Thank you. I am heading out to work on it. Will start small. I very much appreciate the suggestions.
09-28-2017, 09:10 PM
Someone mentioned rust. I had a issue this year with my fridge being unreliable on propane. The permanent fix for me was removing the burner tip and knocking out a bunch of fine rust particles. They came from the flue chimney. These innocent looking particles are pushed-up by the gas flow and clig the little burner's holes, preventing a reliable flame. Since the clogging was sporatic, the fridge's run time was sporatic.
09-29-2017, 08:54 AM
Cleaning seems to have done the trick. She's a 2009 model and the previous owner took great care of the roof but doesn't appear to have ever cleaned any of the compartments. If the cleaning didn't do the trick I will take the burner off and soak it in denatured alcohol. Appreciate all of the suggestions and information.
