Old 12-17-2018, 02:45 PM   #1
water leak
I have a 2017 champagne and we discovered water on the floor in the bedroom next to the closet.
we think the water line leading to the washer (which we do not have and do not use the washer spigot for anything and is closed) might have busted. we are going to look, but my question is:
is there a shutoff valve for the line leading to the washer?
thanks for your help.
dntforche is offline   Reply With Quote
Old 12-17-2018, 06:00 PM   #2
Witch Doctor's Avatar
Not that I have seen, only shut off would be the hot or cold connections, don't think there is anything before them, constant pressure. I don't think they are plex but regular hose. This is a guess, FR. Makes different changes all the time, nothing is ever done the same.
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 12-17-2018, 06:36 PM   #3
racer4's Avatar
On my Cedar Creek, the washer drain line runs along the sidewall inside a "cover", at floor level from the closet towards the door.
They use a "trapless" (no P-trap) device in the drain line. If it gets loose it will leak and get the carpet wet.
I have read about others having that exact problem.
Mine does not have shut-off valves for the washer supply lines that I have seen. I can see the water supply lines inside the front storage compartment, on the left, right below where they go to in the closet. I would look there for valves.
Chris and Pat
2016 Ram 3500 Cummins Aisin Dually, 4.10 axle, Auto Flex Air Ride Rear Suspension, Pace Edwards JackRabbit tonno, Transfer Flow aux fuel tank, B&W RVK3600 hitch
2017 Cedar Creek 36CKTS, MORryde IS, Disc Brakes, 17.5"
racer4 is offline   Reply With Quote
Old 12-17-2018, 06:46 PM   #4
Coach
If he's not using the drain where would water in the drain come from? Our Sandpiper has pex lines running to the washer. I believe there are plastic 90 fittings at the floor level where the water lines go vertical. Is there an access panel at the base of your laundry space where you could get a look?
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
valleyduo is offline   Reply With Quote
Old 12-17-2018, 07:08 PM   #5
Old Bleu's Avatar
We have the washer connections in our Silverback, but doubt we'll ever us them. I added a set of caps to the spigots, just in case they leaked or curious kids tried to open them. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
2019 Cedar Creek Silverback 33IK
2016 RAM 2500 Laramie Cummins Turbo Diesel
Old Bleu is offline   Reply With Quote
Old 12-17-2018, 07:12 PM   #6
SilhouettePenny's Avatar
Look for red/blue water supply lines in the front basement area to the left after you open the door. They run across the upper back side of the storage area. If you're not using the W/D simply add a shut off valve anywhere in the lines. Don't confuse the red/black hydraulic lines connecting to the front leveling jacks.
2017 F350 Dually 6.7
2019.5 Hathaway
He who dies with the most tools, wins!
SilhouettePenny is offline   Reply With Quote
Old 12-18-2018, 11:07 AM   #7
Fifth Wheelers's Avatar
Have a 2016 Champagne model 38el. The water lines for the washer run under the bench seat by the window. There is a false bottom inside the bench that give you access to the lines. You can also get access by removing the bottom drawers on the dresser. At least this is how the 2016 lines run. Good luck.
2016 Champagne EL38
2016 Dodge Ram 3500 DWD
Fifth Wheelers is offline   Reply With Quote
Old 12-18-2018, 12:04 PM   #8
I have never seen shut-offs to those W/D spigots either.
That would be my first mod if I buy one equipped for a W/D.
Especially for winterizing.
Days Camped: '18=51 '19=58 '20=110 '21=94
Old 12-22-2018, 01:43 PM   #9
Gr8Dane777's Avatar
Ditto. Exact same thing happened in our 2018 38el. Was leaking at the waterless trap fitting under the bench. Did everything possible to stop the leak, ended up having to take it back to the dealer and they replaced the pipe.
Gr8Dane777 is offline   Reply With Quote
Old 12-28-2018, 12:47 AM   #10
Also check your window for leaks.
Rick & Paula Birch
2017 Cedar Creek 33ik
2015 Lance 2295
2018 GMC 2500 Denali
Nights camped 2018=60
Azdigs is offline   Reply With Quote
leak, water, water leak
