Old 01-04-2019, 08:41 AM   #1
Water leak
Good morning, I have a cedar creek 29Ik fifth wheel and the galley tank it is not holding water and thereís water and dripping out of the area around the large 4 inch pipe coming out of the bottom of the trailer. Black tank and bath grey tank seem to be working fine. Plan on removing panels today try to figure out whatís going on. Anyone else had a problem like this. Any help would be appreciated thank you
Joepoohbah is offline   Reply With Quote
Old 01-04-2019, 09:58 AM   #2
Have you been below freezing? It sounds like something may have froze. Let us know what you find out
spock123 is offline   Reply With Quote
Old 01-04-2019, 10:08 AM   #3
Always Learning
Unfortunately, that's what it is going to take to figure this out. Post back once you find something.
Checkout my site for RVing tips, tricks, and info | Was a Fulltime Family for 5 years, now we're settlin' down for a spell
Old 01-04-2019, 09:07 PM   #4
Water leak
After removing the panel and the foil and the insulation found that the inch and a half gate valve on the tank side the flange was broken. Itís a four bolt pattern and it seems they use the bolts to drawl it in and the clamp broke. Looks like it mightíve been a little short from the factory but it worked for three years. Have an RV repair guy coming with the parts to fix on Tuesday. I have a bucket under it right now but with the valve in the open position along the water goes through and not much goes into the bucket. Weíll get it fixed and put insulation back and panel back and hopefully everything will be fine
leak, water, water leak
