12-16-2016, 12:56 AM
Westlake "G" tires how are they working out?
My 36CKTS came with a set of Westlake G tires. I'm on the fence about getting rid of them or not. Wonder what kind of luck others are having with them. We travel about 4,000 miles a year with enough junk in our trailer to support us for 2-3 months at a time. Inquiring minds want to know..
2015 Chev Silverado 3500 dually D/A
2016 Cedar Creek 36CK
B&W Patriot 18K, Trail-Aire pinbox,
Level up, dual panes & all that stuff...
12-16-2016, 05:50 AM
World Wide Wanderer
How close are you to the individual tire weight limits?
I ran Westlakes for a couple of years on a lighter trailer with no problems, and I know a few people that have run them on heavier units with no problems.
However on my last trailer they were too close to the weight capacity to make me comfortable so I upgraded to Maxxis.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
12-16-2016, 07:40 AM
I only put on about 4000 miles on mine this year, so far so good.
2008 Dodge 3500 Dually, Cummins. Amsoil Bypass Oil Filter, 36 Gal aux fuel tank. Mag Hytec Trans pan. Mag Hytec Diff Pan. 6 speed autostick. 3:73, Timbrens, Smarty JR. Equipped.
2016 Cedar Creek 38FB2, Hydra Star disc brakes,
400 watt Rich solar on top,200 watts of suitcase
12-16-2016, 08:24 AM
I had them on my first Cedar Creek and I put over 10,000 miles on them. The Cedar Creek that I have now came with Goodyear G614 but they aren't cheap. When they wear out another set of G614 will go on camper
12-16-2016, 08:54 AM
My Cedar Creek came with the Westlake tires on the trailer we bought new in April 2015. So far we have pulled the trailer over 12K + miles with these tires and I will use them for one more year before replacing them. I check the air pressure and wheel lug nut torque every time we pull the camper, this is checked in the morning when the tires are cold. I also check tire temps at every stop we make with an IR heat gun.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
12-16-2016, 08:58 AM
We've had 2 sets of the WestLake G rated tires on 2 different 5ers. The first one was bought used and we put an additional 6000 miles on them. No issues at all. Air pressures were always max and our weights were always under GVW and the max capacity of the tires.
The second set came new on our 38EL. And unlike others we've had, they're nitrogen filled from the factory. So far, only 2000 miles, but they're performing well. Air pressure is near max, and GVW is under max.
For us, the phrase 'performing well' means 1) no blow outs 2) no tread separations 3) tires roll well and 4) I don't have to adjust the air pressure constantly.
Jim
2019 Coachmen Mirada Select 37LS
12-16-2016, 09:08 AM
I am not having any problems............at least not since I had the axles aligned.
I also wanted G614's.........which will be my next set sometime......but other additions cost so much I put it off. But they seem ok.
I keep 110 psi in them. They are 14 ply tires. I have discussed this tire at length with CC Warranty folks and they claim they researched tires when Goodyear de-rated their tires, and the Westlakes came out on top. Now, I'm sure price had a lot to do with it, but if you buy a new set, they aren't that cheap.
Seems the tire industry has succumbed to the offshore cost factor. Maybe one day that will change.
I'd hate to be the one to advise you on anything with tires, and then you have an issue.........but I can only say that for me, I'm going to watch them closely but keep them till either wear or some problem dictates a new set. I have about 8-10K miles on them.
FROG AR-0019-242
12-16-2016, 10:22 AM
Phat Phrog Stunt Crew
I have Westlakes E on my Wildcat for the last 3 yrs with 18,000 miles on them. They still look good and I plan to replace them before 20,000miles.
2014 Wildcat 327ck
12-16-2016, 01:53 PM
We are running Westlake C tires on a Flagstaff 27 trailer for about 18000 miles and have had no issues. We use a TPMS and run them at the max pressure.
12-16-2016, 03:08 PM
Had the Westlake E rated tires on my 340RK when I bought it used earlier this year. Towed from seller location to campground in San Diego (60 miles) with no issues, but I knew I had E rated tires that were not original to 5'r that had a max PSI rating of 80, but the rims were rated for 110 psi. I went to replace the Westlakes with Sailuns' but found there was no inventory anywhere on the west coast area. I ended up going with the Goodyear 614's G rated. Fantastic tire. 5'r behaves very well under highway speeds and is much more stable. Just got done towing from San Diego to Phoenix, AZ and then down to the SE corner of AZ. Tires were great.
Alan
2012 Ram 3500 DRW Crew Cab, 6.7 HO Cummins
2014 Columbus M-340RK
'69 Chevy C-10, 396BB
12-16-2016, 06:43 PM
Global Nomad
West Lake tires
Just finished our first year using the Westlake G on my 2016 36CKTS. Have pulled the rig 9,463 miles, no problems. Tires were nitrogen filled, but on the road could not find filling stations, so added air.
Steven J. Scheinin
2015 RAM 3500 4X4 6.7L CTD Dually pulling a
2016 Cedar Creek 36CKTS (Center Kitchen Three Slides)
12-16-2016, 06:53 PM
Aren't Westlake tires made bu the Onhhunglo tire company, LTD?
12-16-2016, 07:45 PM
I have Westlake G rated tires on my 2016 Cedar Creek 36CKTS and have put about 10000 miles on them. Run them at max cold pressure of 105 psi and about 1000 lbs under their max load carrying capability per tire. I have tire pressure and temperature TPS on them and notice that they seem to run cooler than the Goodyear G614 that I had on my other 5th wheel. My other 5th wheel weighed about the same as this one. No problems to date.
12-16-2016, 09:46 PM
Global Nomad
Originally Posted by JohnE
I have tire pressure and temperature TPS on them.
What TPS system are you using, and where did you purchase it? Did you install yourself?
Steven J. Scheinin
