Old 03-22-2018, 08:08 AM   #1
steelpony5555's Avatar
Wet bolts dry
One other thing...check your wet bolts before you head out....I was replacing tires and when I looked at the center bolt in the spring hanger I saw daylight??? Here the bolt had rounded out the hole and had a half inch gap. The others were fine. But to get a new spring hanger you have to go thru Lippert. While checking on line for spring hangers I saw these bushings that said would eliminate the need to grease the bolts??? Has anyone else seen these or used them?? I will be greasing my bolts a little more often........
From Central Texas
2014 Cedar Creek Silverback 29IK
2010 Dodge Laramie 3500 Dually
My Steelpony....2007 HD Ultra Classic...done up in a memorial to the 343 firefighters who died 9/11
Never Ever Forget....yes I was a Volunteer FF for 20 years........
steelpony5555 is offline   Reply With Quote
Old 03-27-2018, 07:10 PM   #2
dieselguy's Avatar
A good welding shop can fill in the elongated hole and drill it out to size or make a replacement hanger and weld it on, but if Lippert will send you one ... go with it. The never lube bushings are what I think you are talking about. Never is a pretty final word. I put a set on a trailer a few years back because I couldn't get replacement brass bushings till after the guy want to be back on the road. We took a look at them late last year. Of the ones we took apart to look at, one was worn thru and the other 3 although intact, had kinda deformed and worked into the gap in the spring eye itself. I have no idea of the miles that were on them. Shackle bolts all have serrated heads that are pulled into the shackle hole. The inference fit is supposed to keep them from spinning. Some installers don't realize that and try to turn the bolt head instead of the nut. Was your bolt free spinning or still held by the serrations?
dieselguy is offline   Reply With Quote
Old 03-29-2018, 10:28 AM   #3
Since it was the head that was rounded out I would say it spun. Wonder if the neverluubes were installed and still lubed them if that would give it a little extra protection???
From Central Texas
Old 04-03-2018, 09:05 PM   #4
dieselguy's Avatar
steelpony5555 ... if you go ahead with the bushings, here's a Note in ETrailer's description section of them.
"Note: Never Fail bushings should be used with standard suspension bolts only. Do not use wet bolts with these bushings as the grease can cause the bushings to degrade."
bolts
