Originally Posted by camaraderie
You've definitely got a multistage as that is ALL FR has used since before 2015. Your pair of T105s carries around 220 amp hours. When depleted to 50%...the MAXIMUM Bulk charge they will accept will be around 50-55amps for the first stage of charging which might last for 20 or 30 minutes. So if your existing model charger can put out 55 amps then you are perfectly sized for quickest charging. Buying bigger will not get you there quicker! You should also have at LEAST 25 amps capability for minimum performance. With 55 amps it will take around 6 hours to fully charge to 100% from 50%...with a 3 stage charger. Don't shortchange this as you will slowly kill battery life if you do not take the extra time to get to 100%. Good choice...good luck with them.
THANK YOU! This is exactly the type of information I was looking for!!!!
When not in use, the RV is stored in the barn with commercial/shore power attached. So it should have ample time to get to 100% charge. When it's parked for over a week, usually I let the converter/charger fully charge the batteries and I then use the battery disconnect switch and attach (after 24 hours) a BatteryMinder to keep the batteries full and desulfated.
I've read a lot of articles supporting the move from 2 12v to 2 6V and specifically calling out the Trojan line of deep cycle batteries. At $170 a piece I'm expecting good results and high quality.
Again thanks for the excellent info!
