Old 12-21-2017, 01:28 PM   #21
keith52's Avatar
The Progressive EMS was only reading one leg. First they sent me new sensors, and that didn't work. Then they sent me a new circuit board. Now it is reading both leg1 and leg 2. Give them a call and they might be able to tell you what happened. I would kiss the microwave good-bye and get yourself an new one. I don't think they are "repairable"
2014 Chevy CC Duramax 4X4 Long Bed
2017 Cedar Creek 36CKTS
MORryde independent suspension with disc brakes
keith52 is offline   Reply With Quote
Old 12-22-2017, 10:24 PM   #22
Sound like you might have had a loose neutral,causes Up to 150volt to burn out the micro and clock. And Iíd you didnít have a separate ground the surge protector couldnít stop it
dgsearcy55 is online now   Reply With Quote
Old 12-23-2017, 11:14 AM   #23
Global Nomad
Scheinin's Avatar
Where would I check that?
Steven J. Scheinin
2015 RAM 3500 4X4
6.7L CTD Dually pulling a
2016 Cedar Creek 36CKTS (Center Kitchen Three Slides)
Scheinin is offline   Reply With Quote
Old 12-23-2017, 11:25 AM   #24
Ch excited for a loose wire in the power cord where it connects to the camper
Old 12-23-2017, 11:27 AM   #25
Spell check , check for a loose wire , mine was loose in the yellow twist lock connector
Old 12-23-2017, 11:35 AM   #26
Global Nomad
Scheinin's Avatar
I will check as soon as it stops raining. Thank you.
Steven J. Scheinin
2015 RAM 3500 4X4
Old 12-23-2017, 11:54 AM   #27
Did you check the micro for a blown fuse . Takes a 20 amp ceramic fuse . Itís behind the touch control. Remove the upper grill and there is a screw at the top of the control,push up on it and itíll hinge down . You should be able to see it and reach it with needle nose pliers.
Old 12-23-2017, 12:59 PM   #28
Global Nomad
Scheinin's Avatar
No fuse behind upper grill. Just vent to outside
Steven J. Scheinin
2015 RAM 3500 4X4
Old 12-23-2017, 01:00 PM   #29
Global Nomad
Scheinin's Avatar
Could not see access to go behind control panel.
Steven J. Scheinin
2015 RAM 3500 4X4
Old 12-23-2017, 05:30 PM   #30
When I take off the top grills thereís a screw to remove the h keypad assy
Old 12-23-2017, 05:36 PM   #31
Global Nomad
Scheinin's Avatar
Do you take off the top grill by removing 4 screws?
Steven J. Scheinin
2015 RAM 3500 4X4
Old 12-23-2017, 05:54 PM   #32
I believe I can see the screw I the crack between the control and grill. Once you remove that screw push up and itíll hinge down and youíll see that fuse. I bet your service center didnít touch it because most believe in throw it away and sell u a new one. A fuse is a dollar and fifty cents
Old 12-23-2017, 06:05 PM   #33
Have you tried to find a YouTube video of replacing the fuse ? But I have seen the hood microwaves for $75 at Loweís
Old 12-25-2017, 02:18 PM   #34
Global Nomad
Scheinin's Avatar
Thank you, dgsearcy55, but I don't see anything that looks like a fuse. Do you see it?
ID:	158994   Click image for larger version
Steven J. Scheinin
2015 RAM 3500 4X4
Old 12-25-2017, 03:23 PM   #35
Global Nomad
Scheinin's Avatar
Found it. Checked fuse, it is not blown. I guess I will buy another microwave, which doesn't upset me, but since I do not know what blew this one, I don't know how to prevent it from happening again. Click image for larger version
Steven J. Scheinin
2015 RAM 3500 4X4
Old 12-27-2017, 02:27 PM   #36
Some times the power surge gets the copper trace on the back of the control board . If you feel like it take control board loose and look at the rear of the board near the transformer . I soldering gun and may be a small jumper where the trace was . I've fixed some from storms and power surges that way.
Old 12-27-2017, 03:41 PM   #37
Global Nomad
Scheinin's Avatar
I checked the circuit board behind the control panel, pictured above, nothing lose or blown. It gets to a point where the time exerted in trying to fix this, exceeds the cost of a replacement. I have reached that point. I am still looking for the reason for the surge.
Thank you for your assistance.
Steven J. Scheinin
2015 RAM 3500 4X4
