Old 09-19-2020, 02:37 PM   #1
White hose beside low point drain
There is a white hose under the trailer beside the low point drain that is running water. Can't figure out why and where the water is from.
Help is appreciated!
tcrossan is offline   Reply With Quote
Old 09-19-2020, 02:57 PM   #2
rracer5's Avatar
Fresh water tank drain? And it may be draining because you may be getting water into the FW tank due to a stuck check valve in the water pump. Or, if you have water in the FW tank, then the drain valve may not be closed completely.
2014 Prime Time Sanibel 3250
rracer5 is offline   Reply With Quote
Old 09-19-2020, 02:58 PM   #3
Jim34RL's Avatar
Picture would help to identify what it might be?
My Creek has three low point drains plus the fresh water tank drain so, that is why I asked for a picture!
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 135K+miles
Old 09-19-2020, 03:18 PM   #4
bubbles's Avatar
Drains would be capped off. Sounds like the overflow/vent for the holding tank and yes, it might be because the water pump may have a stuck check valve if there is shore water hooked up.
Old 09-19-2020, 05:24 PM   #5
Shut city water off. Cycled pump on-off a couple times. Turned city water on. No overflow water.
Problem solved.
Thank you gentlemen!! I'll be able to sleep tonight!!
TCrossan
2020 CC Hathaway 34IK, 2012 F350
Old 09-20-2020, 10:09 AM   #6
rracer5's Avatar
Not necessarily on all makes/models. Mine is just a shut off valve at the end of a very short stubby hose sticking out from the underbelly cover.
Old 09-20-2020, 01:26 PM   #7
I was told that was overflow for onboard fresh water tank. Tech filled as part of new unit walk through and said “just fill until it starts flowing out that tube”.
Mikeytheb is offline   Reply With Quote
drain
