09-23-2020, 01:06 PM
#21
Well, darn. I’m out of ideas.
Is there anything to which the bundle can be zip tied?
2017 Coachman Chaparral 336TSIK
2015 F350 6.7
09-23-2020, 01:07 PM
#22
Global Nomad
I will be checking on that first thing in the morning.
Steven J. Scheinin
2015 RAM 3500 4X4 6.7L CTD Dually pulling a
2016 Cedar Creek 36CKTS (Center Kitchen Three Slides)
09-23-2020, 01:14 PM
#23
The top pic looks like a stick on zip tie mount. Looks like the double sided tape gave out. Is there a clean spot that looks like this used to be stuck to?
2019 Rockwood MiniLite 2104S
2017 F150 3.5 EcoBoost 10 spd 4x4
09-23-2020, 01:20 PM
#24
Global Nomad
Yes, on the back of the cable bundle and the piece attached to the slide out, however, there is not sticky residue to indicate it was attached there. I now think the plastic piece on the back of the bundle broke off from a piece on the slide out and the clean spots is where it rubbed to the break off point. I will research further.
Steven J. Scheinin
09-23-2020, 01:36 PM
#25
Ahh, my mistake. I looked at the zoomed in pic....looked like a zip tie mount on the bundle. Looking at your original pic, I see that that is the end of the plastic strap.
09-23-2020, 02:17 PM
#26
Originally Posted by U.S.ArmyVeteran
In your picture look at the lowest point. There is a tie-wrap with "something" attached to the back. Now look straight up and you will see a rectangular "something" that that seems to match what you have on back of cable. Notice that it is not covered with dirt and dust.
I am going to give you a WAG and say that is where it goes.
Good Luck!
Saw and was thinking the exact same thing. X2
09-24-2020, 11:14 PM
#27
My 2016 Cedar Creek Silverback 33IK did the same thing. I believe the plastic strap was attached to the bracket in one of the photos and would flex as the slide moved in and out. I took a small hinge and attached it to the end of the plastic strap with machine screws and nuts and then attached the hinge to the bracket. I had to watch the slide move in and out to make sure the hinge was positioned correctly.
2016 CC Silverback 33IK
2020 F350 Lariat SRW FX4
09-25-2020, 04:03 AM
#28
Global Nomad
That sounds like the solution. Would you be kind enough to post a photo so I can do the same thing?
Thank you, very much.
Steven J. Scheinin
09-25-2020, 06:58 AM
#29
Busy this morning. Will try to get photos later today.
09-25-2020, 12:00 PM
#30
I will try to attach photos, I am not real good at this. Hope this helps.
09-25-2020, 12:34 PM
#31
Perfect. Great pics!
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
09-26-2020, 01:51 PM
#32
Tex50,
Thanks for the pics.
It sounds like I should be prepared to do the same repair on my CC 36CKTS.
Chris
Chris and Pat
2023 Ram 3500 Cummins Aisin Dually, Auto Flex Air Ride Rear Suspension, B&W RVK3600 hitch
2022 Grand Design Reflection 303RLS
2024 Winnebago Minnie 2327TB B&W Continuum Hitch
09-27-2020, 06:53 AM
#33
I might have to carry a hinge with me, LOL
2008 Dodge 3500 Dually, Cummins. Amsoil Bypass Oil Filter, 36 Gal aux fuel tank. Mag Hytec Trans pan. Mag Hytec Diff Pan. 6 speed autostick. 3:73, Timbrens, Smarty JR. Equipped.
2016 Cedar Creek 38FB2, Hydra Star disc brakes,
400 watt Rich solar on top,200 watts of suitcase
09-29-2020, 12:13 AM
#34
Global Nomad
Thank you all for your comments. Based on those comments I realized that the backing on the bundle of wires was attached where the 2 screws were, and broke off just before the screws. I removed those two screws and the broken backing. I will move the backing a few inches, drill new holes and attach them with the screws. Problem solved.
Steven J. Scheinin
09-29-2020, 04:24 AM
#35
This is the part that is used a lot for slide wire looms. https://www.etrailer.com/Accessories...LC1346281.html
Retired 2020.
46 Years RVing and no end in sight.
2018 Ram 3500 SB Limited, CC, 6.7/Aisin, 4X4, SRW. Comfort Ride Energy Absorbing Hitch.
2020 Cedar Creek Hathaway 34IK, Reese 19K Sidewinder PB.
09-29-2020, 11:14 AM
#36
Flex Guard Slide-Out Kit
If you're replacing what appears to be missing from your photos, you'll need a Lippert Flex Guard Slide-Out Kit; they come in single, double and triple widths to match, in theory, the number of wire runs needing support. You can search that phrase on Amazon and find them as well as from other online sites. I'm looking at a triple right now that sells for $36.20 each.
I repaired mine earlier this summer and they need to be replaced. Although I have only a single wire run I'm going to replace with either the double or triple to provide a better, more stable and stronger bridge for those cables.
09-29-2020, 08:16 PM
#37
Wires Fell Down
I to bought a lippert part to replace my broken flex, on my 2014 ckts when my last one broke. Bought 2 to mount on each side where it pins on the slide where it moves.
