09-23-2020, 07:58 AM
Global Nomad
Wires Fell Down
I have a 2016 Cedar Creek 36CKTS. I have been in the same campground for 3 months because of Covid-19. A few days ago the bundle of wires on the passenger side under the slide fell down. I don't see how they were attached so that I can refasten them. Could someone who has this RV please look and tell me what is used to fasten them up. Here is a picture:
Steven J. Scheinin
2015 RAM 3500 4X4 6.7L CTD Dually pulling a
2016 Cedar Creek 36CKTS (Center Kitchen Three Slides)
09-23-2020, 10:03 AM
My 2016 Creek is in storage right now. But if my memory serves me right the wire loom is held in place by a spring that connects to the slide frame and than to the wire loom. Look for any springs lying on the ground.
Someone else might be able to post a picture for you.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
09-23-2020, 10:04 AM
It looks like the wire support, and it's broken loose at the outer end. That's a common issue. Most people take a hinge and attach it to the support and to the bracket (piece hanging down in the top center of the pic with the two screws in it) to keep it from breaking again.
Gotta go campin!
09-23-2020, 10:10 AM
Part-Time Campground Host
Mine is attached to a long hard rubber strip. It sort of folds up when the slide is put in. Here's a few pics:
Craig & Cath
Days camped since 2015(retirement): 1687
09-23-2020, 10:24 AM
X2
You can see part of the support (called a rubber strip by cboss) attached on the loom with zip ties and it broke loose from the attachment point right where Bama explained.
09-23-2020, 10:27 AM
Global Nomad
Filed under Cedar Creek
Each unit is different. I was hoping someone out there has a 2016 36CKTS Cedar Creek to show me what their underside looks like.
Steven J. Scheinin
09-23-2020, 10:46 AM
Bama and 5picker gave you exactly what you need. If you hold your wire loom up you will see exactly where the black flat plastic support is supposed to attach, as the other end of that black plastic piece is still attached to the slide. You can either fix as Bama said, or replace the flat support strip which you can buy at any RV parts site/store.
And yes, every unit is slightly different, but most component parts are exactly the same.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
09-23-2020, 11:06 AM
In your picture look at the lowest point. There is a tie-wrap with "something" attached to the back. Now look straight up and you will see a rectangular "something" that that seems to match what you have on back of cable. Notice that it is not covered with dirt and dust.
I am going to give you a WAG and say that is where it goes.
Good Luck!
What He said...............
09-23-2020, 11:34 AM
here..............
09-23-2020, 11:37 AM
Originally Posted by U.S.ArmyVeteran
here..............
Exactly.....
Global Nomad
Good Luck!
I see that, but I don't see how to attach the wire bundle to that point. There is no place for straps, no hole for spring, no sticky residue where it is shinning to indicate glue or adhesive was used.
Steven J. Scheinin
09-23-2020, 11:42 AM
That's because the plastic piece that those bottom screws are holding on, is broken from the plastic piece that's ty-wrap'ed to the wire loom/cable.
Gotta go campin!
09-23-2020, 11:47 AM
I'd do something different. Have someone run your slide in and out while you observe how the wires move. I suspect you'll see that you can use heavy weight electrical zip ties for the fix. It doesn't have to be factory perfect, just close enough so the wires move freely and without chaffing.
09-23-2020, 11:49 AM
Global Nomad
Thank you, now I understand.
Steven J. Scheinin
Global Nomad
Thank you, I will give that a try.
Steven J. Scheinin
09-23-2020, 12:06 PM
Also, if you have another slide, it should look the same if it has a wire loom/support, hopefully unbroken
09-23-2020, 12:11 PM
Global Nomad
The opposite slide on the Cedar Creek is completely different. That was the first thing I checked.
Steven J. Scheinin
09-23-2020, 12:18 PM
Wires Fell Down
What are these? Can you take a better picture of each?
2017 Coachman Chaparral 336TSIK
2015 F350 6.7
09-23-2020, 01:03 PM
Global Nomad
Originally Posted by lesptr
The cable bundle does not reach that bracket. That was my first thought. But, that would have been too easy.
Steven J. Scheinin
