07-21-2020, 06:34 PM
Yellow stains in vinyl flooring
We have a 2020 34IK which we've used about 8 trips. I've noticed yellow stains in the vinyl at the entry door. We keep a small throw rug there and thought maybe the stains were from that. This evening I was in the trailer and noticed more, darker and larger area of the same.
Has anyone experienced this?
Kind of appears to be glue bleed through but it is a mystery to me.
Need to look close as it doesn't show up well in the photo.
07-21-2020, 06:57 PM
I have not had this issue. However, I am thinking adhesive bleed-threw.
07-21-2020, 07:36 PM
Check the backing on the throw rug. It may not be playing well with the floor covering.
One more thought. Be sure you're looking at it under natural light. Some LED lights can cast a yellowish hue when shining on certain surfaces. I have an under cupboard LED light strio that causes my counter top to look yellowish. Off with the light and it's normal.
07-21-2020, 08:27 PM
TitanMike
I considered the rug at first but the stains are in front of the refrigerator even more and darker where there is no rug.
There were no lights on as I just had the door open to put some things inside preparing for our trip in August.
Trailer is out of witty now so I guess it's my problem to solve.
TCrossan
2020 CC Hathaway 34IK, 2012 F350
07-22-2020, 01:45 PM
That's exactly what it is. The glue bleed or the BHT we have the same issue with our MH frustrating because there is nothing you can really do.
07-22-2020, 01:47 PM
It was very common on carpet if the wrong padding was used
07-22-2020, 02:16 PM
Well, maybe a FR representative can offer some insight. I'm sure the congoleum makers had a specification for the proper adhesive. So I hope that's what was used. We have carpet only in the bedroom so the flooring will be pretty unsightly before long.
07-22-2020, 02:56 PM
Yellow stains on vinyl flooring.
I have the same issue on my MH 374TS 2010 near the fridge and it is glue bleed. The stains have not migrated or expanded for many years unfortunately there nothing that I am aware of that would qualify as a recommendation for removing the yellow stains.
07-22-2020, 04:28 PM
Something similar happened to me except mine was a pretty pink discoloration. Here's my thread to review. Based on the newness of your unit, the dealer should be able to replace this.
https://www.forestriverforums.com/fo...nk-201016.html
ArkRVHog
2018 Forester Model 2801 QSF
Katy, TX
OTR 2024-22 / 2023-29 / 2022-52
2021-51 / 2020-29 / 2019-71 / 2018-49
07-22-2020, 07:26 PM
I'm sure I read another thread about this issue, maybe six months ago. I seem to remember that it included a manufacturer comment. Should be easy to find with Search.
Larry
07-22-2020, 08:45 PM
I have seen the backing from a rug have a yellowing effect on the flooring of a previously owned trailer. I do not leave any rugs on the floor during storage. They are rolled up and stores themselves.
07-24-2020, 09:23 AM
I installed floor coverings for approx 25 yrs, Hung it up about 20 yrs ago !
We fought with all the Vinyl Manufacturer for years, about the LOW Price Vinyls turning Yellow, never did really find a reason, I did see many floors where it looked to be caused by throw rugs, but many turning Yellow where there was NO rugs ???
07-24-2020, 09:29 AM
Yes, I have seen the yellowing on linoleum and vinyl tiles, mostly the ones installed before 2012. I was never sure if it was a manufacturing defect or a problem caused by reaction to cleaners. All I use on mine now is a microfiber mop with water and occasionally a spray of Dawn dish soap mixed with water. A water only follow up after using the Dawn mix.
