Old 02-07-2019, 02:35 PM   #1
12 Volt disconnect switch
When I turn it to on position, nothing happens. I then turn the ignition switch on the Ford on, and then the disconnect switch seems to function. Seems like something is wrong, but I have no idea what. Any ideas. Thanks.
Palpjl is offline   Reply With Quote
Old 02-07-2019, 02:40 PM   #2
Mr. Dan's Avatar
This doesn't not appear to be a general electrical system issue but is more likely to be unit specific. What brand/model RV do you have -- so we can move this to a better sub-forum?
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 26; booked = 42
Old 02-07-2019, 03:09 PM   #3
12 volt disconnect switch
2017 Leprechaun. Thanks
Old 02-07-2019, 03:13 PM   #4
Mr. Dan's Avatar
So I'm guessing a Leprechaun is a Coachman Motor Home - so here we go.
Old 02-08-2019, 02:38 PM   #5
Adrian Gordon's Avatar
I also have a Leprachaun (2018). Not being critical, but I cannot tell what you are describing here. Can you give us a little more detail? When you say 12 volt disconnect switch, are you talking about the coach battery disconnect switch? How do you know nothing happens, do the lights not come on? Something else? Where is the switch located?
2018 Coachmen Leprachaun 210RS with DW, a German Shepherd and the cat.
Adrian Gordon is offline   Reply With Quote
Old 02-08-2019, 03:50 PM   #6
Additional
It is the 12 volt coach disconnect switch which turns off all 12 volt power to the coach. It is located with all the other switches. It is round and turns either on or off by turning either left or right. When I turned it on, it did not work. In other words no 12 volt lights, pumps, generator, etc could be switched on. I called Coachmen on another issue and was told to check the two 5 amp fuses located left of the batteries under the steps. I did. They were both good, but just removing and replacing them seemed to trigger a FIX. Thanks for your reply.
Old 02-08-2019, 05:34 PM   #7
Great, glad that it works. Would still love to know why it worked when you switched on the ignition switch. Do you have a switch and wiring installed which enables you to start your engine from the coach battery if the chassis battery is dead?
Old 02-08-2019, 05:52 PM   #8
Have no clue why it worked when I turned on ignition. No, as far as I know I have no switch to start vehicle with coach batteries. Wish we did.
Old 02-08-2019, 06:03 PM   #9
When just removing and replacing a fuse seems to "fix" things take a close look. The fault could be caused by a loose connection (solder joint or fuse contacts) that may cause a fault again. Give things a good "wiggle test" to make sure your "fix" is permanent.
"A wise man can change his mind. A fool never will."
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 02-08-2019, 07:21 PM   #10
Hairline
Can even be a hairline crack in the fuse element.
In 1973 I had an Opel GT in which I could run the heater fan or the wipers. Running both killed both. But if I turned the ignition off for a few seconds, it would magically heal. One day I noticed that the fuse link had a bend in it. Shining a flashlight behind it revealed the tiny crack which would open with moderate current flow and re-weld when the voltage was removed.
Larry
Larry-NC is offline   Reply With Quote
12 volt, switch
