Old 11-26-2019, 05:18 PM   #1
'14 Concord TS300 slide
Have been having slide issue with passenger side slide. Have taken it to a VERY reputable dealer to have fixed. It was just making a loud squeaking sound at first...they added some braces and said it was a factory defect. That didn't work and I took it back. They adjusted again and it seemed ok until I made the three hour drive back to my home. Slide had come off the tract and was out of line by about 1/2 inch. Took back and they have had my coach for over 90 days now. Owner told me just flat out that they can't fix it. They have put new parts on, said it wasn't totally square, etc. Anybody else run into this scenario??
drhud is offline   Reply With Quote
Old 11-30-2019, 12:22 PM   #2
SeaDog's Avatar
welcome to the forum its a great place to get your questions answered. There have been tons of slide problems you might try using the search function at the top right of the page and see what pops up
Retired Navy
2016 Flagstaff 26 FKWS
Old 12-12-2019, 07:45 AM   #3
Witch Doctor's Avatar
Are you saying your Concord is a 2014 model? If you are, I would find it hard to believe that if it was out of square, that this hasnít been a problem, sounds to me it is more like a rack problem. Do you know if they pulled the whole slide off the unit? Most dealers wonít do that, that is my guess. If I where you I would give Jason Johnson a call at Coachmen, and explain to him your problem , he is the service rep for the Class C Concord division. If you canít find his # let me know and I can give it to you. He could atleast give you some ideas of what to do next.
Coachmen M/H
Concord
2018 / 300 DSC
Old 12-12-2019, 07:50 AM   #4
Which slide is it the bedroom or living room? Either one itís impossible to get to the rod that runs from the motor to the lower gear without pulling that whole slide out.
Coachmen M/H
Concord
2018 / 300 DSC
slide
