Old 11-03-2019, 12:13 PM   #1
125992's Avatar
2015 Leprechaun 220QB fresh water tank bypass
Does anyone own the above MH and can tell me where or if there is a fresh water tank bypass? I read online here that it maybe under the bed near the converter. I've removed paneling and have followed the water inlet to the FW tank, but I don't see any bypass. Is it possible that there is no bypass for the FW tank?
Please help. Any suggestions are appreciated.
Thanks,
Bill
Bill
2015 Coachmen Leprechaun QB220 (purchased 4/2018)
125992 is offline   Reply With Quote
Old 11-04-2019, 09:42 AM   #2
Commercial Member
ES_FR's Avatar
125992,
We would be happy to assist you with this question regarding your fresh water tank bypass. Please contact Ron Ross in our Customer service department through the following personalized and direct link: http://www.coachmenrv.com/DirectServ...84572549426535.
This direct link is provided for your convenience in order that we may resolve your concerns as quickly as possible. We will strive to respond to you within 24 hours of receiving your correspondence.
Respectfully,
Forest River
ES_FR is offline   Reply With Quote
Old 11-25-2019, 06:27 AM   #3
Witch Doctor's Avatar
Did FR ever get back to you? They forgot to install mine, so they sent me one and I installed on the line from the tank to the pump.
Coachmen M/H
Concord
2018 / 300 DSC
Old 11-25-2019, 10:25 AM   #4
125992's Avatar
Yes, they did get back to me. I don't have a FW tank bypass valve.
"It sounds as if there is not a fresh water tank bypass valve, so very likely it is the older style and the winterizing instructions for the 2014 & older models will apply."
Bill
Old 11-25-2019, 02:13 PM   #5
i would still put one in between your strainer and your fresh water tank easy to do, plus then for sure you won’t get antifreeze in that tank and you have away to shut off that tank if you ever have a leak, just go to ace buy a 1/2” valve and 2 clamps and install it, I do not like having any way not to shut it off. Just call it a safety valve you never know, and if you have to change the pump you can stop any water from flowing out all over the place. Just my advice to you. If you change that pump that water will continue to flow out until you reconnect it to the new pump.
bypass, fresh water, tank, water, water tank
