Weigh your coach by axle and check and set your air pressures. Over inflation will also cause this problem. When mine was new they have over 100#'s in them. Running 82 now and it rides and handles much better.
I too have done the CHF and installed Sumo Springs on the front, but the air pressure check should be the first, and free I might add, think you should do.
Hope this helps.
2014 Coachman Mirada 29 DSSE
2009 Jeep Wrangler Unlimited
