03-19-2019, 09:54 PM
3 drain valves on Prism 2200
Just purchased a 2019 Prism. Why are there 3 gate valves? One on curb side and 2 on the street side. What is the procedure? Is the curb side valve black or grey?? If black, open it first... then the curb side black...when complete... empty grey..??
Thanks. John.
03-19-2019, 09:55 PM
Need answer soon... leaving Campground in morning.
03-19-2019, 09:58 PM
I can't help since I've never seen a gate valve on the curb side.
03-19-2019, 10:17 PM
Me neither.
I’m ???? On a new rig.
03-20-2019, 07:16 AM
Is there a sewer hose connection on the street side? You calling things correct in your post? I have never heard of sewer line being on that side, maybe in Europe like England. These are not plex lines are They? That's how confused I am. Can you post a picture of things your questioning.
Coachmen M/H
Concord
2018 / 300 DSC
03-20-2019, 07:24 AM
generally, if you have only one toilet, you'll only have one black tank, which is usually on the driver side outlet, along with the gray tank outlet.
if you have an additional outlet on the passenger side, it's probably gray water from a kitchen sink on that side of the RV, or the shower if you have a 'split' walk-thru bathroom, etc.
Having an outlet on the passenger side is no different than the other, but your hose will need to reach much farther. Which side you dump first probably matters not.
The Turners...
03-20-2019, 07:43 AM
I,m pretty sure the gate valve on the curb side is for freezing weather, you can close it and open the valve on the street side and then no water will be left in the drain pipe to freeze......Bruce
Bruce and Sandy
2007 Scepter 42PDQ--Sold
2018 Coachmen Leprechaun 26DS Chevy
03-20-2019, 12:13 PM
Per the dealer. The black tank has 2 valves. Not sure why. But that’s their answer.
03-20-2019, 01:04 PM
I should have mentioned, for freezing weather, if you have a sewer hook up, you leave your gray tank valve open (so it can completely drain) and close the black tank on the curb side valve, and open the black valve on the road side. This empties the drain pipe that runs underneath the motor home, so it can't freeze.....Bruce
Bruce and Sandy
03-20-2019, 01:15 PM
Always Learning
Not so humbly, I think your dealer is full of it.
My guess is that:
- the passenger side's rear most handle is gray for the shower.
- the next handle is likely near that but in front of it and is most likely the handle for the blank tank.
- the driver's side handle is likely mid-ship and for the sink gray tank.
The only way to find out is to pull them open + close them fairly quickly. See if it's gray or brown water that comes out. That will tell you if it's black or gray.
Then, once the tanks are empty. Close all of the handles. Run water into the kitchen sink for like 5 minutes. Go pull handles one by one to see which lets water out. Let it drain out completely. Close the handle.
Repeat for the shower.
Repeat for the toilet.
03-20-2019, 01:52 PM
Some pics might help.
Here's a pic from a dealers website showing the 2 street-side valves.
The one on the left with the handle facing the front is the black tank valve. The one on the right with the handle facing the photographer is the grey tank valve.
Here's a pic of the curb side. I don't see any valves here.
It's possible you have a second gray tank for the kitchen sink, and it's valve could be on the street side, but that's kind of unusual.
2011 Traverse LT, 3.6L, FWD
03-20-2019, 02:44 PM
I don't see a sewer line hook up on the street side, if it's like the plumbing lay out of a Concord, they might have added a transfer valve only from the sink and probably shower. If they did they are getting smart. In a Concord the sink and shower drain in one tank on the street side, then the bathroom sink has it own tank on the curb side. The problem comes from the Chassis layout. People have talked about installing a transfer line from tank to tank, the capacity sucks. Maybe that is what they have done there now. Best my small mind can think of. But I don't see a sewer hook up on the street side, do you? Is there one there OP?
Coachmen M/H
Concord
2018 / 300 DSC
03-20-2019, 04:07 PM
This is the correct answer. Kitchen and bathroom are on curb side. The curb side black thank valve is to close off the transfer tube to the street side.
This is a 22 foot MSB MH, not a large TT or FW.
Frank
Frank & Brenda
Thor Windsport 27K TST 507 Tire Monitors
2012 Jeep Liberty Limited Jet 4X4, Hopkins TOWD light wiring, Blue Ox baseplate W/Ready Brute Hercules tow bar and Ready brakes
03-20-2019, 04:54 PM
Thanks. John.
I take it no one explained this to you at purchase? Never heard of a curb side one. Wouldn't surprise me the way they build them today. Are you asking us what color YOUR valves are? I have seen separate grey water tanks.
03-20-2019, 06:37 PM
Just another great mystery solved by this community. Nothing stumps forum members. Just shows every unit is different.
Coachmen M/H
Concord
2018 / 300 DSC
03-26-2019, 05:28 PM
Wow, that is interesting. Our Coachmen Freelander 20CB (transit chassis) has three handles too, but two are gray and one is black. One of the grays is just the shower and the other does the kitchen and bath sinks. All three are in the back drivers side.
Jay
03-26-2019, 07:16 PM
Cora, retired RN
Black tank valve
I have a 2019 coachmen Freelander 21 rs. I also have a black tank valve on the curb side. It is connected to same line as black tank valve on street side. Grey tank valve is separate.
03-26-2019, 07:19 PM
Cora, retired RN
I was told only to open street side first, then open curb second. I forgot this first time I used it an got a little messy
04-22-2019, 08:44 AM
I have the same model.
Valve on passenger side is first valve for black tank. Drivers side is black and gray tank valves.
After hooking up, I open the passenger's side first (you'll hear it flush out), then I go to the drivers side and open that valve to let it drain. They have 2 for a safety featue, to keep crap from becoming a big mess and released by accident. After dumping the black tank and a few flushes, I close the valves and move to the gray tank.
1 black tank, 1 gray tank, and 1 fresh water. That's it.
Again, it's for no accidental crap drains.
ALSO - keep your p-traps filled - especially the shower if not used frequently. Keeps the gray tank nasty smell away
Feel free to drop me a line on any questions - we LOVE ours and have learned a lot about it the last year!
