Old 03-16-2020, 08:37 AM   #1
2019 Leprechaun 319mb
319mb Furrion Solar connector
My 2019 319mb has a Furrion solar connector near my entry Door. Iím considering using a solar suitcase for a supplemental charging alternative but... Iím not sure if I need a charge controller installed and if so where can I put it since I canít seem to find any reliable wiring diagrams.
Iím looking for some reliable info on what I need to buy to accomplish this charging scenario and where to install the wiring etc. I know this seams rather vague but I believe Iím not the first to try this and am looking for ideas. TIA
Bill659651 is offline   Reply With Quote
Old 03-16-2020, 08:42 AM   #2
SeaDog's Avatar
most suitcase units that I have seen come with their own charge controller
Retired Navy
2016 Flagstaff 26 FKWS
Old 03-28-2020, 04:08 PM   #3
Apparently no one has put the furrion connector to use. I'm surprised that they would put a solar connector on the rig and not have any documentation as to how to use it.
Old 03-30-2020, 07:59 PM   #4
sa1jzm's Avatar
Iíve used the one on my Freelander. Itís wired into the inverter to only charge the coach battery(s) so if youíre on shore power itís of no use.
sa1jzm is offline   Reply With Quote
Old 04-05-2020, 10:19 AM   #5
I have a Freelander 20cb and use a Renogy portable unit that I added the mating connector to. On the 20CB, the whole solar prep is a Furrion connector and a fuse and wire running to the house battery. I think the fuse is 10amp and there is no controller. I bought matching connectors on-line somewhere (don't remember where now). Added one to my Winnebago too for trickle charging the batteries from the panel.
Jay
2016 Coachmen Freelander 20CB
2007 Winnebago Journey 39K
jaynwhite is offline   Reply With Quote
solar
