Originally Posted by JohnMirada
We have 2015 Mirada 35LS with two 13.5 A/C units. When the outside temp gets in the high 80's and above, it seems the front A/C can't keep up and inside temp will be between 81 & 84 with the A/C unit running continuously. We live in Florida and will encounter those higher outside temps a lot. The 15.0 A/C unit is an option on this model. Will upgrading to that improve our A/C performance? Dealer has already looked at our unit twice and said everything is working as it should.
Have you addressed the heat problem in the front? The front glass is brutal with the heat that it lets in. We have used reflectix before and it is quite economical. I also bought a screen to put up inside...Both options help a great deal.
The key is getting the heat off the glass. I have measured temps over 110. We ultimately bought a Magne-shade which goes on the outside. This was our best solution. We can now run and keep the AC around 78 with no problems during the heat of the day. The back unit is run cooler to help compensate for the extra work the front has to do.
Bottom line - it has been quite comfortable this year so far...and we leave the front shade up so we can see outside.
