Old 07-13-2024, 02:05 PM   #1
Atwood Levelegs controller location
Hi all. 2011 Coachman Mirada 32DS motorhome. Can't seem to locate the controller for my Levelegs. Just crawled under the length of the coach and couldn't find it mounted underneath the body. I tried following the wire coming from the legs, but they went into larger looms to who knows where.Click image for larger version
ID:	301983 Also, checked inside the side boxes, on the ceilings of the compartments. I found a unit mounted on the ceiling of the compartment directly behind the drivers front wheel, but it doesn't look like the pictures of the controllers. Before I start tearing into it, thought I'd see if anyone can tell me where it's mounted for sure. I'm going to replace the Atwood unit with a Gama board which will be totally manual with a remote.
roggenburger is offline   Reply With Quote
Old 07-13-2024, 07:41 PM   #2
Atwood Levelegs
Found it!! It was the unit in my picture. The mounting cover fooled me.
Hard to see into the low compartments with bifocals when you're on the ground looking up at the ceiling of a side compartment.
I'll share finished pictures of the Gama unit.
cat, controller, location
