brand new 2021 Coachmen Mirada 35OS
Hello everyone. New to the forum and new to our Mirada 35OS. I have a few questions that I was hoping someone could shed light on.
1. The outside awning has speakers. Little tweeters that sound terrible. They are being powered by a Boss MC900B. The Boss unit is a 4-speaker amp. Two of which are the tweeters in the awning arms. But no where else can I find speakers nor can I hear anything from anywhere else except the tweeters...... where are the other two speakers? Ive tried following the wires to see where, but no luck. The Boss 900 is mounted under the sink, behind the exterior TV hooked up to 2 speakers only? seems cheesy
2. Satellite roof wiring access. The roof has a gang box with wiring for satellite, but doesn't indicate where any wires go. In that box is RG6 (pink I believe) and another RG (might be 59, but black)and some power wires that lead to nothing. What are the power wires for and where does that RG6 and 59 lead to?
3. Filling fresh water tank. How? I see and know where to hook up, but shouldn't you open a valve of some sort to relieve pressure as it is being filled up? How do you know its full? Im assuming there is an overflow that indicates when the tank is full? maybe on the bottom just keep filling the fresh water until water comes out of the bottom through <some line>....
