Old 03-04-2020, 11:15 AM   #1
Camco Tank Rinser
Anyone else experience a problem using the Camco Water Heater Rinse Wand? I used and the wand blew off and into the Water Heater.
Any wisdom on if it hurts anything or creative ideas how to get it out? The drain hole is pretty small. I can see it with a flexable camera but not enough room to maneuver it out.
Name:	Camco Wand 2.jpg
Guy & Patt
2017 Coachmen Pursuit 27KBPF
gmac is offline   Reply With Quote
Old 03-04-2020, 11:20 AM   #2
Remove heat element,larger hole to see and work in! Youroo!!
Old 03-04-2020, 11:21 AM   #3
Trailer Park Supervisor
NJKris's Avatar
Maybe a coat hanger doubled up and wrapped with tape, sticky side out? What a PITA.
NJKris is offline   Reply With Quote
Old 03-04-2020, 11:24 AM   #4
Kanadian Kamper
kenandterry's Avatar
Wow. Thatís one of the first RV tools I bought years ago. Never thought to look at the connection on mine.....but I will now.
It shouldnít cause any trouble......operative word is shouldnít.
It might float around because itís plastic, but Iím not sure of itís density.
Hereís a picture of the only tool that might grab it for you, or the tips given so far.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 03-04-2020, 11:26 AM   #5
Also while the heater is out cut a washing machine supply hose in half and screw onto a garden hose and put it in the Heater hole! Now watch the White Crud flow out of the Drain hole! Youroo!!
Old 03-04-2020, 11:26 AM   #6
Camco Wand
Thanks for suggestions
Might try both.
Problem with heating element is that it is on inside part of tank and will have to see how to access - behind bedroom wardrobe
Guy & Patt
Old 03-04-2020, 11:28 AM   #7
Kanadian Kamper
What brand of water heater have you got?
Ken and Terry
Old 03-04-2020, 11:31 AM   #8
cboss's Avatar
Super glue it in.
Craig & Cath
2018 2902WS Rockwood Ultra Lite
2017 Ford F250 Lariat, 6.2 gas
Equalizer Hitch w/ 4-Point Sway Control
Days camped since 2016(retirement): 837
cboss is online now   Reply With Quote
Old 03-04-2020, 11:34 AM   #9
Atwood GCAA-10E
Guy & Patt
Old 03-04-2020, 11:39 AM   #10
I ordered a new one from Amazon and the wand was cracked where it attached to body. Took the wand off and boiled it for 10 minutes in case I have to leave it in there. Didn't melt or soften.
Guy & Patt
Old 03-04-2020, 05:48 PM   #11
Wow, I never thought of this happening! Thanks for the warning, I’ll hold onto the wand the next time I use it.
2018 F 150 Supercrew 6.5 bed 3.5 EB Max Tow
Jfkmk is offline   Reply With Quote
Old 03-04-2020, 06:24 PM   #12
Originally Posted by Jfkmk View Post
Wow, I never thought of this happening! Thanks for the warning, Iíll hold onto the wand the next time I use it.
X2
Mike134 is offline   Reply With Quote
Old 03-04-2020, 06:41 PM   #13
No rotating machinery in water heater for it to get ground up in. Will probably just lay on the bottom of the tank doing nothing. Next time you pull the anode out shine a flashlight int he hole. Might just be laying there where you can fish it out with a piece of wire or whatever your imagination comes up with.
"A wise man can change his mind. A fool never will."
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
tank
