Originally Posted by TitanMike
On my truck the manufacturer incorporated the cats into the exhaust manifolds.
A bugger to replace and almost impossible to saw off with frame and engine blocking access.
The solution is for vehicle manufacturers to make it harder to just make like a worm, crawl under, and have unobstructed access to the cat.
Look at the vehicles that are victimized. Most have easy access to the target.
What's puzzling is how manufacturers have no problem hiding relatively inexpensive items that need periodic maintenance or repairs but can't figure out how to make cat converter just as difficult or impossible to reach by a thief.
Those things get HOT! 1200 ºF ! How much other stuff under the hood gets baked and fails (electrical connectors, wire insulation, plastic brackets, plastic wire looms, drive belts, hoses for A/C, coolant, vacuum, and fuel) due to the extra heat.
My daily driver is a 2006 Tahoe. DW's former vehicle was a 2006 Yukon XL, essentially the same vehicle. Both vehicles have converters very close to, and directly connected to, the exhaust manifolds. They heat has baked off the plastic heater-hose connectors, failing so frequently that Dorman makes aftermarket replacements. The underhood electrical connectors are fragile.
GM puts cowlings all around the engine. On DW's vehicle, when I took those off to change spark plugs, all of the flexible wire looms just crumbled away. The only reason it didn't happen on the Tahoe is that the state Highway Patrol garage had taken those cowlings off and thrown them away.
