Cell Booster Installation
Hi, I’m installing a cell booster system on our 2013 Coachmen Freelander Motorhome. I reviewed a utube video to mount the external antenna on the tv mast and called Weboost to verify that it is acceptable location. It is provided we aren’t moving.
The most difficult part is drilling a single hole in the roof to run the cable thru. The best location for us is back driver side overhead cabinet. I only want to run that single cable so I don’t need to create a cable box on the roof (won’t add solar or anything else on the roof). If you have an idea, suggestion to where inside the cabinet to drill and seal the roof opening thank you so much.
