09-23-2020, 09:48 AM
Class C motorhomes
Do most class c motorhomes come with a spare tire?
09-24-2020, 09:09 PM
Some do, most don't.
Jim
2019 Coachmen Mirada Select 37LS
09-24-2020, 09:13 PM
09-24-2020, 09:42 PM
My 2016 3010 DS did.
09-24-2020, 09:47 PM
Thanks appreciate the input
09-24-2020, 11:01 PM
Some models do come with a spare, some don’t. Some don’t even have room to put a spare wheel/tire. Our Sunseeker did come standard with a spare; I made sure of that before I decided on that model.
2020 Sunseeker 2440DS on 2019 Ford E-450, Trekker cap, Topaz paint
09-25-2020, 07:43 AM
Thanks again looking at new Thor Four Winds or Chateau class c.
09-25-2020, 08:16 AM
First Rate Primate
My Mercedes Benz Sprinter Coachman Prism has the MBS spare mounted between the rear frame rails and the MBS jack and lug wrench under the passenger side floor mat.
09-25-2020, 09:38 AM
Appreciate your input, thanks.
09-25-2020, 11:37 AM
In 2019, Forest River had a poster comparing Sunseeker LE features to other brands, including spare tires. With the competitors FR chose for the poster, those other models did not have standard spare tires. So, you’ll want to shop carefully, and if a spare tire is not a mentioned feature, assume there isn’t one included.
09-25-2020, 11:46 AM
If you have a Cordovan spare made in Mexico throw it in the trash. Mine lasted less than 300 miles before throwing a tread and damaging the brake line. Get a good tire to put on the rim.
2017 Sunseeker GTS 2800 QS
2017 Jeep Grand Cherokee toad
1987 Sunstream (sold)
Retired BTC USN
Chesapeake, Virginia
09-25-2020, 12:37 PM
My MH came with a China bomb spare. Had to use it due to a front tire blowout. Unfortunately the spare had only 50 psi (should be 75-80) and no way to air it up. Drove the 40 miles to home but as far as I was concerned the tire was no longer usable so I threw it away.
Got a new spare now and because I saw how much trouble (and dangerous) it is to get the spare down from its spot I added a winch. If you get a MH with a spare definitely add the winch if it has the normal single nut hold down method.
BIRDS AREN’T REAL
09-25-2020, 01:22 PM
Very good information and advice, again thanks.
09-25-2020, 01:24 PM
Appreciate your inputs have switched to Goodyear Endurance on my fifth wheel.
Will do, thanks.
