Old 04-20-2020, 05:42 PM   #1
Coachmen 319MB slides binding
I have a 2018 Coachmen Leprechaun 319MB. The front slide is binding on one end. It got stuck in the out position at a campsite last weekend when this happened for the first time. If I assist by pushing/pulling while pressing the inside switch, we can eventually get it to move in/out. The motors appear to be working fine and I have lubricated the top and bottom slide teeth but it still is binding. Are there other locations to lubricate or adjustments that can be made?
Is there a manual override that I can move the slide with a socket or wrench? If so, where is the access point located? We are on the road again this weekend and need to get it fixed.
Any suggestions are appreciated.
tantle1961 is offline   Reply With Quote
Old 04-21-2020, 07:10 AM   #2
Carl17's Avatar
There are video on line from Schentic not spell right. There is a over ride at the control box . again watch video . Last resort there are two motors at top of slide that have too be remove so slide can be push in by hand .. Sounds like there mite be a problem with slide it self like a bad roller or out of square. Find videos ,if i find will post they shroud be right here in these forums.
Carl & Bette
2018 Leprechaun
NEW YORK
Carl17 is offline   Reply With Quote
Old 04-21-2020, 07:13 AM   #3
Carl17's Avatar
timing slide
https://youtu.be/hSafAnjxIV4
https://youtu.be/0dIQp0h97xY
https://youtu.be/DviEbWT3lUo
Carl & Bette
2018 Leprechaun
NEW YORK
Old 04-21-2020, 07:30 AM   #4
SeaDog's Avatar
Are your jacks down and the rig level when you are extending or retracting the slide (assuming you have Jacks)
Retired Navy
2016 Flagstaff 26 FKWS
Old 04-21-2020, 10:55 AM   #5
Coachmen 319MB slide controller
Thank you for the videos. Do you know where the controller is located in this model?
Old 04-21-2020, 01:26 PM   #6
Thank to all for your help.* I did get the slide motors synchronized and it appears to be working properly now.
Old 04-21-2020, 06:25 PM   #7
Carl17's Avatar
Smile good
Thats great . Some time its better do do things your self than a dealer.
Carl & Bette
2018 Leprechaun
NEW YORK
Old 04-23-2020, 07:13 PM   #8
It is in one of the compartments on the driver side up front. It is in the ceiling part of the compartment and a little hard to see/read.
Favfour is offline   Reply With Quote
coachmen, slide
