Old 02-15-2020, 05:20 PM   #1
Coachmen Concord 2012 301ss
Is there no fresh water drain? besides the low water valves under the bed?
drolloc is offline   Reply With Quote
Old 02-16-2020, 08:23 AM   #2
SeaDog's Avatar
welcome to the forum its a great place to get your questions answered. Not sure I know what you mean by low water valves. Most potable water tanks have a drain usually located somewhere on the outside of the rig by the tank.
Retired Navy
2016 Flagstaff 26 FKWS
Old 02-16-2020, 11:13 AM   #3
Just 3 little low tank valves I've traced all the lines. Must be a common issue, just bought this used with 7k miles on it, even desler had no clue!
Old 03-28-2020, 03:48 AM   #4
Witch Doctor's Avatar
I donít know if you found your drain valves yet, I have a Concord and mine are under the refer where the return air grill is, there are 3 valves there to drain your hot and cold lines and your fresh water tank. Mine is newer but I doubt that they changed the location.
Coachmen M/H
Concord
2018 / 300 DSC
Old 03-28-2020, 10:52 AM   #5
My 3 valves are under the bed with the water tank,I will look under the fridge grill next seems odd you would have to unscrew a grille vent just to drain your tank? Thanks
Old 03-28-2020, 10:59 AM   #6
well my bed doesnít lift , like said my unit is newer, I guess they changed, I would only think that they have 1 set of valves. Doubt if you have them behind the grill then. Also you have unscrew all access panels in my unit to get to things like the water pump, valves , shower drain also shower connection and the black flush valve. So I donít think itís that strange. But I think you found yours.
Coachmen M/H
Concord
2018 / 300 DSC
