Old 04-21-2024, 05:12 AM   #1
Coachmen Concord Seats
Hello, we bought a 2015 Coachman Concord recently. The only issue I have is I'm 6'5 and the driver's seat is so far forward it makes driving difficult. I have called Coachman asking if there is hardware to move the seat back and also went to General RV and Mentor RV and they had no idea other than buy new seats. I can't believe there isn't a hardware base that can be installed to move the seat back. There is about 12 inches of space to move the plate back but there is a 1 inch rise in the floor behind the seat. Any ideas for a resolution? Thanks, Terry Stull
Terry0903 is offline   Reply With Quote
Old 04-21-2024, 06:08 AM   #2
Kanadian Kamper
kenandterry's Avatar
Okay……your question is more about an issue in the cockpit of your vehicle, and not an issue with the “house” part of your Coachman Concord.
Is your vehicle built on the Ford, Chevrolet or Sprinter chassis?
You’re asking about a metal seat base being moved, not a problem with the seat/fabric material.
As always, a few photos always help, especially the area of the 1” rise behind the seat base you have today.
Ken and Terry
kenandterry is offline   Reply With Quote
Old 04-21-2024, 06:16 AM   #3
bikendan's Avatar
Moved thread from the General Tech and Repair section to the Coachmen Motorhomes sub-forum since the OP's questions are specific to a Coachmen motorhome and not general questions.
Old 04-21-2024, 02:47 PM   #4
RedLdr1's Avatar
The seat base, and adjuster, is most likely a Ford part. Here is a picture of a E-450 passenger side base off EBay. You should be able to adjust the seat forward and backward over a range of several inches. If Coachmen installed a swivel base, that allows the seat to rotate to face the rear, that may be the problem.
Does the seat move forward, or backward, at all?
Wayne
2024 Sunseeker 2150SLEF / 2025 Ford E-350
RedLdr1 is online now   Reply With Quote
Old 04-22-2024, 06:23 AM   #5
Seat Bracket
Good morning, it does move back and forth. It needs to go back about another 8-10 inches. I went to 2 dealers and one said they had no idea how to fix and the other said go to www.Seats4rv.com. Very nice seats but no bracket solution.
ID:	298961   Click image for larger version
ID:	298962   Click image for larger version
Old 04-22-2024, 06:27 AM   #6
Seat Bracket
This is a Ford 450. Thanks, Terry
Old 04-23-2024, 12:10 PM   #7
RedLdr1's Avatar
I've seen seat re-locator kits on EBay that should work. Basically another bracket that goes between the existing seat bracket and floor to move it back a few inches. Here is an example of a set.
The question I have is can your seat base be moved further back without it hitting the wall behind it?
Wayne
Old 04-23-2024, 12:31 PM   #8
Yes, there is about 8-10 inches behind the seat. There is a 1 inch rise in the floor right behind the seat the 6-8 inches behind that
Old 04-23-2024, 12:33 PM   #9
RedLdr1's Avatar
Then a universal kit should allow you to move it back as both ends will go up the same distance.
Wayne
coachmen
