Coachmen DC Voltage Help
My coach is a 2001 Sportcoach DS 400.
No DC voltage. New batteries, properly wired, clean terminals. No blown fuses. No voltage to the fuse panel. No voltage to the disconnect switch at the entrance door. Before I start crawling around on the ground and through the coach, before I start taking the interior apart, Help!
Does any one know where the coach/chassis connect/disconnect solenoid(s) are. Barring that, any advice as to whom else i might ask.
Thanks in advance and look forward to hearing from someone soon.
